Go Back   InterNACHI Message Board > Specific Inspection Topics > Plumbing
Plumbing Contains discussions about plumbing.
Old 6/26/08, 9:30 PM
Matthew Hopkins Matthew Hopkins is offline
Please Note: Matthew Hopkins is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Double TPR
Here's a good one. I like that they used a second TPR instead of a 90 deg bend. The question is, do we think this is dangerous? It's clearly improper.
My thought was that it is dangerous as it may require more pressure to build up before it will actually release, but i'm not up on my engineering enough to know whether that's really the case.
Old 6/26/08, 9:43 PM
Michael Larson's Avatar
Default Re: Double TPR
That's just stupid.
The second TPR is acting a a check valve in the wrong direction.
Yes it's very Dangerous as effectively there is no TPR.
"Never underestimate the difficulty of changing false beliefs by facts."
Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
or
Minnesota Home Inspector
Old 6/26/08, 9:46 PM
Yes, this part of we does.
Larry Kage
231 929 3525
Professional Inspector and Infrared Thermographer serving the Traverse City, Michigan area and beyond.
ITC/FLIR CERTIFIED BUILDING SCIENCES THERMOGRAPHER
ITC/FLIR CERTIFIED LEVEL 1 THERMOGRAPHER
Old 6/26/08, 9:52 PM
Barry Adair's Avatar
We say it's a lot cheaper to just buy and install a plug
That's what all of these components have accomplished
badair
ADAIR INSPECTION
972-487-5634
Residential-Commercial-Construction-EIFS-Infrared Thermography
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
life is the random lottery of events followed by numerous narrow escapes...accept the good
Old 6/26/08, 10:23 PM
James F. McKee's Avatar
very very not good....and then some....
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 6/26/08, 10:29 PM
James H. Bushart's Avatar
It certainly defies the manufacturer's installation instructions...should there be an argument anywhere.
You may as well had sweated a cap on the end of it.
Old 6/26/08, 10:34 PM
Marcel Gratton's Avatar
Safety Issue, Repair: I recommend removing the TPR valve installed within the discharge piping. TPR dip tub must be positioned within the top 8 in. of water heater to be effective. Present installation could cause injury/death.
Marcel Gratton, CMI
On The Level Inspection
Gatineau, QC
http://onthelevelinspection.com/
Old 6/26/08, 10:42 PM
Why sweat it when you can screw it...
Marcel Gratton, CMI
Gatineau, QC
Old 6/26/08, 11:10 PM
The temperature relief valve, required and designed to prevent the water heater from exploding, is incorrectly installed. Recommend that a qualified plumber be contracted to repair or replace as necessary.
Old 6/26/08, 11:31 PM
The Temperature Pressure Relief valve required and designed to prevent the water heater from exploding is correctly installed... However, the other TPR valve installed within the discharge tube isn't and could cause injury/death.
I recommend that a licensed plumber be contacted promptly for appropriate repairs.
Marcel Gratton, CMI
Gatineau, QC
Old 6/26/08, 11:46 PM
Marcel,
Typo or misinformation
6" not 8"
Watts http://www.watts.com/pro/divisions/watersafety_flowcontrol/support/support_t-p.asp
Correct Installation of T&P Relief Valves Important Instructions: Relief Valves and Automatic Gas Shut-Off Devices
Combination temperature and pressure relief valves with extension thermostats must be installed so that the temperature-sensing element is immersed in the water within the top 6" (152mm) of the water storage tank. They must be installed either in the hot outlet service line or directly in a tank tapping. Combination temperature and pressure relief valves that do not have extension elements must be mounted directly in a tank tapping located within the top 6" (152mm) of the water storage tank. Valves must be located so as to assure isolation from flue gas heat or other ambient conditions that are not indicative of stored water temperature.
badair
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 6/26/08, 11:59 PM
Originally Posted by badair
Marcel,
6" not 8"
Neither, it's actually 5 7/8 inches according to some local buildling code but will an inch or two make that much of a difference...
Marcel Gratton, CMI
Gatineau, QC
Old 6/27/08, 2:12 AM
Crap, I hadn't actually noticed the second was going the wrong way, VERY BAD. Gotta call the realtor back. Thanks guys.
Old 6/27/08, 8:20 AM
You may also want to consider amending the report to your client. A verbal warning is not sufficient, IMO.
Larry Kage
231 929 3525
Old 6/27/08, 3:41 PM
Kenneth Lott's Avatar
Kenneth Lott Kenneth Lott is offline
Most definitely dangerous, first of all it is backwards, you need to report this guy before he gets someone hurt or worse.
Double lugged breakers? dbook Electrical 7 4/30/08 1:35 AM
Double tapping question mroe Electrical 17 8/30/07 9:32 AM
Double Tap Questions jkogel Electrical 6 6/28/07 10:46 PM
Doorbell transformer double tap bsmith Electrical 11 4/17/06 1:48 PM
Double Taps rwand1 Canadian Inspectors 30 3/29/06 8:16 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
