Any ideas?
| Need a home inspection in Nebraska? Check out InterNACHI's listing of Nebraska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Nice setup.
Indicates they often have issues however. Is this a multi family? |
Its an older home with cast iron or galv iron drain pipe, I bet the pipe is nearing the end of its useful life and plugs often. What feeds into the line? If there is a washing maching on that drain there is a lot of lint the gets into the drain and can cause problems.
How many trees are in the way of the drain pipe as it exits the home to the street???? hummm??
They should just hang a sign on the pipe saying its done replace me please. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
Cross connect if they connect that to the domestic water supply with a hose or other means. Looks like they have also eliminated the clean-out unless there is another somewhere.
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
| Pool drain cover recall update | llosciale | Florida Inspectors | 2 | 6/11/11 10:28 AM |
| CPSC Considers Drain Cover Recall By Rebecca Robledo | 4.7.2011 | jhagarty | Ancillary Inspection Services & Additional Topics | 5 | 4/21/11 8:30 PM |
| Condensate Drainage | jevans | Inspecting HVAC Systems | 28 | 11/27/10 2:55 PM |
| French drain tied into main drain | rwashington | Plumbing Inspections | 6 | 2/16/07 11:04 PM |
