Any thoughts or comments on kitchen drain line?
| Need a home inspection in Indiana? Check out InterNACHI's listing of Indiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Yeah, those are always fun.
I would just state that it was installed unprofessionally and you should considier having it replaced. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
Are you wondering about the "sloped section" at the front of your picture?
Supposed to be 1/4 inch per foot up to about a "max" of 1/2' per foot for horiz runs. If exceeded, a 45 degree ell or vertical run should be in place. So.... as that does appear "funky", here's the thing, if it's a 45 degree ell (hard to tell in pic if 22 or 45) at the top and bottom of the slope, most plumbers are gonna say it's fine. The slope of the trap arm looks questionable as well, once again, hard for me to tell. If it is an incorrectly installed 22 degree elbow, a longer tailpiece woulda/coulda solved that problem. No one ever said Do It Yourself meant, Do It Right. Is that what you were wondering? |
Yes, thats how I called it, just wanted another opinion. Thanks for the reply.
I would think the trap needs to be off the other sink drain if thats a disposal and DW drain on the right side which is not shown.
Should I also mention that the trap, trap arm, drain pipe look like a DYI kit from a hardware store...I forgot the name of it but looks like it.
Very artistic!
Did it drain right? "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Strangely enough they always seem to..
In addition (in CA), an air-gap is required for the DW. The DW drain-line is connected directly to the disposal.
OK thought I would wait a bit.
(looks like c--p) Just write it up based on the 90 attached to the basin and be done with it. |
I know the OP asked about the drain but I have a couple thoughts on this photo. What is this copper line(arrow), is it for the DW? I would think it should be more protected from damage. Also should not the electrical wire for the disposer be protected from damage? The DW drain line looks high in the photo. I am thinking it hooks up high under the sink. Don't newer DW come with an air gap in the drain line already installed?
David InterNACHI #08051301 NYS Lic. #16000038229 NYS DEC Cert # T4865884 518-505-8305 HouseAbout Home Inspections HouseAbout on Facebook NY Capital Region Chapter InterNACHI |
I would not assume there is a disposal as the plug could be for the dishwasher. If there is no air gap the drain line is not high enough.I t needs to go up to the flood rim. What arrow and I might mention the use of putty as being a sign of DIY install. Do not like mixing the metal retaining ring with PVC but the rubber gasket is what holds it. |
sorry forgot to add pix. Does it matter what the cord is for?
No, but it is for disposal or dishwasher.
In this case dishwasher as the cord goes down that way. |
Just the drain line?
How about, "Call a licensed plumber and start over"? |
| TPR Drain Line | jweise | Plumbing Inspections | 0 | 6/10/10 10:11 PM |
| Condensate drain line | scroenne | Inspecting HVAC Systems | 1 | 5/5/10 7:07 PM |
| Condensate line tapped directly into drain in crawlspace | jfrederick | Inspecting HVAC Systems | 6 | 7/1/09 2:18 PM |
| Evaporator drain line | lfoster | Inspecting HVAC Systems | 3 | 7/18/07 8:35 PM |
| TPR drain line touching floor | mpettitt | Inspecting HVAC Systems | 7 | 2/26/06 3:13 PM |
