rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
Besides this trap being too deep, is there a problem with the fact that the drain line is BARELY lower than the drain? Any other issues here?
Thanks in advance.
It will probably make for some very slow draining sometimes, especially if one fills up the sink for any reason, and if other water-using components nearby are also in use.
While I understand that it is not the HI's job to recommend the solution, I would be interested in knowing what the 'experts' would do to correct this issue.
It may be near 4" from the weir to the upper dip. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
It was 5" deep, so I called it out for that. I just wasn't sure there were any other issues. It seemed to drain fine.
Thanks for the replies! |
It starts draining at a height above the strainer in the basin. There will be water standing at the drain strainer area at all times. |
I would write it up as well as at least questionable but would like to have a better reason. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
That's why I said, "It will probably make for some very slow draining sometimes, especially if one fills up the sink for any reason, and if other water-using components nearby are also in use."
It's called "funcational drainage." I do it at all my inspections. I get the dishwasher running, sinks draining, showers draining, bathtubs draining, and toilets flushing to see if I can get water to back up anywhere. It most often happens when things are congregated in the same area, such as a three bathroom house where all three bathrooms are separated only by a wall. Such a test comes in handy during times when the home might be packed with people, such as a same-sex wedding when lots of people come in from out of town, or a major sporting event, etc., and all the water-using systems are being used at the same time. NACHI 2005 U.S. Member of the Year
Peace, love and happiness RR. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Well, to you I say, "Best wishes for health, happiness, peace, and prosperity." You're on your own for love. Gots to go out to Julian for today's inspections. NACHI 2005 U.S. Member of the Year
| Slope of waste drain line. | mlong | Plumbing Inspections | 5 | 4/23/08 9:54 PM |
| At least they put in a drain line | dbush | Electrical Inspections | 17 | 11/2/07 12:03 AM |
| Evaporator drain line | lfoster | Inspecting HVAC Systems | 3 | 7/18/07 8:35 PM |
| How turns can you have on a TPR drain line? | jlybolt | Plumbing Inspections | 8 | 6/10/07 9:35 AM |
