I just could not resist posting this one. It was one of the smaller openings in the supply lines.
I found an apartment complex last week with a return air plenum that contained an open drain to the sewer for the condensate line to drain into. The upstairs apartments had the same set up with the exception that the furnace/water heater exhaust from downstairs also ran through it.
James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas. |
Looks like a cold air return to me. I can't believe these types of fixes that homeowners attempt. |
Kinda makes you want to buy stock in silicon.
Bungalows to Mansions Professional Inspection Services, LLC dba 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
Maybe it was cold and they had trouble with the trap freezing.
In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
If that was a leaking waste stack, I would really worry.
I posted one duct that had the gas line running through it a few months back. |
"Click to Enlarge" ![]() A blow torch and extension cord should work fine. |
"You can't solve a problem with the same level of thinking that created it" |
| 2 water heaters, combined TPR and pan drain line | lfoster | Plumbing Inspections | 11 | 12/18/07 12:23 PM |
| At least they put in a drain line | dbush | Electrical Inspections | 17 | 11/2/07 1:03 AM |
| Evaporator drain line | lfoster | Inspecting HVAC Systems | 3 | 7/18/07 9:35 PM |
| How turns can you have on a TPR drain line? | jlybolt | Plumbing Inspections | 8 | 6/10/07 10:35 AM |
| Capped drain line vent | rdawes | Inspecting HVAC Systems | 3 | 4/21/07 8:00 PM |
