Old 4/4/06, 10:34 PM
nbhi's Avatar
nbhi nbhi is offline
Default drain pipe
As you can see from the pic, the drain pipe goes thru the bottom of the cabinet, I could not locate the trap. I am assuming that it is beneath the cabinet. I could not locate it in the basement either. Is this a problem?
Attachment 2636
"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison
www.newbeginningshomeinspection.com
Old 4/5/06, 1:57 AM
Dale Duffy's Avatar
Default Re: drain pipe
Gary, call this guy.
Old 4/5/06, 9:29 AM
Russel Ray's Avatar
Originally Posted by nbhi
Is this a problem?
If it were on one of my inspections, yes.
Old 4/5/06, 7:56 PM
nbhi's Avatar
RR, why would this be an issue on your inspection? Is it because you are unable to get to the trap?
Old 4/5/06, 8:08 PM
Dale Duffy's Avatar
Or say you cannot see a trap, therefore you would not be able to determine if one is present. I would doubt myself it is beneath a cabinet, and if it was how would you service it?????
Old 4/5/06, 8:41 PM
Russel Ray's Avatar
Yep. I have to be able to confirm that a trap is present. If it's not visible, then I call it out.
Old 4/5/06, 11:51 PM
Jay Moge's Avatar
Jay Moge Jay Moge is offline
i agree. some people may think that the disposal will act as a trap not realizing that the exit pipe for it actualy sits above what ever water may stay in the unit. can't see it? mayby there's a good reason for that.
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 36 10/27/10 11:21 AM
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 9:16 AM
Identify ABS defective pipe mcyr Plumbing Inspections 6 1/29/09 7:39 PM
Question about mold on the inside of a drain pipe abishop Plumbing Inspections 3 4/11/07 10:35 PM
Proper distance between a washer drain pipe and 220 volt dryer connection rpaul Electrical Inspections 14 1/3/06 10:43 PM
