Is it acceptable to have a drain pipe cut through a HVAC return vent?
| Need a home inspection in Massachusetts? Check out InterNACHI's listing of Massachusetts certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I apprenticed as a plumber for a while and I know that current codes aren't allowing the venting to pass through cold air returns due to the potential that it can carry fire across levels of the home.
Floor space returns are not suppose to have gas piping or waste cleanouts. Also wires can run thru the floor space/bay, but are not suppose to run along the space/bay inside the return.
Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
Did you see the date on David's post OLD. someone is grave digging
Looks like the original post was never answered, and it is a good question ...
| Inspector in hot water after approving unit without drain | rcooke | Canadian Inspectors | 7 | 2/20/08 3:59 PM |
| French drain tied into main drain | rwashington | Plumbing Inspections | 6 | 2/16/07 11:04 PM |
| Water supply pipes and drain pipes running through return air ducts? | aharper1 | Inspecting HVAC Systems | 3 | 9/26/06 12:09 PM |
