Dishwasher drain goes directly to garbage disposal...no Air gap. Is
this ok ?
| Find an InterNACHI certified Hawaii Home Inspector (and anywhere else in North America) |
Here the drain hose would have to go above the bottom of the sink to be acceptable.
As pictured, no go. |
Agree with brian though technically it does need an air gap .
It may have a reverse trap built into to the back of the dishwasher on some models but it is beyond your scope to determine that. "Who wants disposal juice on their dishes" |
thanks everybody
In this situation, I'd still recommend the air gap. It's such a simple fix.
Where I'm located, that's about 50% or more of what I see. Some have a high loop up to the bottom of the counter, but most don't. An air gap is almost unheard of.
Only time I see this as an issue is if the garbage disposal backs up, then the "water" may back up into the dishwasher. This is exactly the way my own home's dishwasher is, and in 15 years, and numerous clogs, we have never had a problem with it backing up. (except when plunging) Worst case scenario is that the owner would have to re-run their dishes. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
"The dishwasher discharges without a visible anti-siphon valve or high drain loop (where the drain line rises above the sink drain and is securely fastened to the underside of the counter).....An evaluation and service by a licensed plumbing contractor is recommended." “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Installing a dishwasher drain line without a listed air-gap device is a prohibited practice in the state of CA.
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Illinois allows a high loop, but not direct connection to disposal
Here it would need a high loop or an air gap unless the dishwasher has a built in high loop.
Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
How many times have we heard the old "never had a problem" So you never write this issue up? I never had a problem with my short down spouts or 40 year old furnace either. Did I mention my car tires have no tread but never had a flat. |
a) Domestic Dishwasher (Private Residence). When a domestic dishwashing machine drain line is connected to the house side of a trap from a sink, the drain from the dishwasher shall be carried up to the underside of the spill rim of the sink. Dishwashing machines shall discharge separately into a trap or tail piece of the kitchen sink and shall not connect to the food waste disposal unit Section 890.710 Food Waste Disposal Units a) Installation. Food waste disposal units shall be trapped separately from any other fixture or compartment, shall be connected directly to the sanitary drainage system, and shall be properly vented. Dishwashers shall not discharge into food waste disposal units. Units may have either automatic or hand-operated water supply control. (See Section 890.1130(a), (b) and (c).) Christopher Currins Certified, Licensed Proudly serving the Illinois Metro-East Illinois Home Inspector Top 5 Tasks for January |
There is the answer.
Like I said, worst case scenario, you have to re-run the dishes. Not a major concern. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
I also find kitchens with no exhaust vent or charcoal filter associated with a rangehood which I could choose to ignore at many Inspections. The list could go on and on but why bother as clients could care less about these things ...right I mean door pads not on cabinets are just noisy and door stops are only needed if you do not put a cast iron dog behind them and do horizontal closet door really need guides ?as all they do is stop them from flapping So. Some people are just too picky,but I am one of them. |
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 36 | 10/27/10 11:21 AM |
| Dishwasher drain vent | jszczesny | Plumbing Inspections | 6 | 11/15/08 2:51 AM |
| Dishwasher Drain | vsantos | Plumbing Inspections | 22 | 10/8/08 4:59 PM |
| Exploding Dishwasher | mbledsoe | Plumbing Inspections | 8 | 2/28/06 8:13 AM |
| Dishwasher Drain Line | msimmons | Plumbing Inspections | 9 | 1/19/06 12:27 PM |
