I come across this condition in condos where access beneath and behind the tub is not readily accessible. Is it possible to reconnect this type of stopper from above? (see photo)
| Need a home inspection in Louisiana? Check out InterNACHI's listing of Louisiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
This should clear it up for you.
You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell Last edited by mlarson; 4/1/11 at 8:59 AM.. |
Thanks Mike, great diagram.
Yes, nice graphic Mike. They can oftentimes be a PIA to get back in properly. Patience is usually required. A bit of vaseline definately helps on older fixtures. Just make sure to run some hot water to wash it through when done.
Too many women in the house with long hair. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
| Condensate Drainage | jevans | Inspecting HVAC Systems | 28 | 11/27/10 2:55 PM |
| Flat drain stopper over shower drain | bhartley | Plumbing Inspections | 7 | 2/18/09 8:46 AM |
| Nice Report on AL Wire Terminations - Enjoy | pabernathy | Electrical Inspections | 0 | 7/2/07 12:35 PM |
