Old 2/20/07, 7:23 PM
Steve Evets Steve Evets is offline
Please Note: Steve Evets is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Draining a mobile home hot water heater.
I wanted to replace the element in a hot water heater that is located within a closet that is not much bigger than the heater itself. I shut off the water, opened a nearby hot water faucet, then put a hose on the drain spigot and turned it on. The problem is that I cannot get water out. There is water in the tank, but it will not drain through the spigot on the bottom.
Add to this, when I unscrewed the bottom wire on the thermostat the wire dropped off because evidently it was not attached at the other end. The problem here is that the heater is turned so far to the right within the closet that I cannot even get my head in there to see where the wire was attached on the other end. Also, where the wire is attached is not within the access panel, but down in the heater where it is difficult to reach. I had hoped that if I was able to get the heater drained that I could rotate it enough to see inside. Perhaps the problem with the water not heating was simply that the thermostat was not properly connected and not a failure of the element.
Am I at call a plumber time? It sucks that this heater has so little access to it since it is in a closet. Thanks in advance for any help or ideas.
Old 2/20/07, 7:29 PM
Brian E. Kelly's Avatar
Default Re: Draining a mobile home hot water heater.
YES
Old 2/20/07, 7:30 PM
Cut an access hole and later cover it with a panel...an idea.
Larry Kage, CMI
231 929 3525
Old 2/20/07, 7:33 PM
tneumann's Avatar
tneumann tneumann is offline
I always pop open the TPR valve to get them to drain.
Also, the drain COULD be plugged with garbage from the bottom of the tank....
Old 2/20/07, 7:50 PM
Originally Posted by bkelly2
YES
I was afraid of that since I cannot even see where that wire from the thermostat was attached. My abilities are only average so I might have succeeded if everything had gone well. It just goes to show--it's always something.
Old 2/20/07, 7:53 PM
I tried that, and that valve drains directly into a drain in the floor of the mobile home. It didn't get the water moving out of the tank which is what I wanted because the way the tank is situated I cannot even get my head into position to look and see where the disconnected thermostat wire goes to.
Old 2/20/07, 7:56 PM
And quite likely a good idea since it would certainly give a better view of exactly where the other end of that thermostat wire was attached. The problem is that is getting a little beyond my everyday average guy's plumbing ability. I am afraid if I did that I might end up regretting it and wondering why I didn't leave well enough alone.
Old 2/20/07, 7:58 PM
Is it possible if I did get it drained that I might be able to then rotate the heater enough to see where the other end of that thermostat wire that came loose goes to and to reconnect it?
Old 2/20/07, 8:58 PM
bandag bandag is offline
Please Note: bandag is a non-member guest and is in no way affiliated with InterNACHI or its members.
If the valve is open I don't see why some water wouldn't drain out, how old is the WH? maybe get a piece of wire and a bucket and shove the wire up the drain valve to see if it is clogged. maybe you can see where that wire goes with a bright flashlight and a mirror. good luck
Old 2/20/07, 9:30 PM
Jeffrey R. Pope's Avatar
I wanted to replace the element in a hot water heater. . .
If you've already got hot water, why do you even need the heater?
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 2/21/07, 12:09 AM
Marc D. Shunk's Avatar
Banned
I don't drain water heaters to change elements. If you keep the spiggots closed, and just turn off the supply valve to the water heater, you'll only lose a little splash of water. No big deal. Sorta the 'finger on top of the drinking straw' effect.
Old 2/21/07, 12:28 AM
sparksnmore sparksnmore is offline
Please Note: sparksnmore is a non-member guest and is in no way affiliated with InterNACHI or its members.
Drain valves on water heaters are bad about getting plugged up.
I've found it's best not to turn off the water first but open the drain valve and flush it out with full pressure first, then shut off the water supply and open some hot side faucets.
Many times a T-P valve will not close once you mess with it so it's best not to touch those.
I think I would disconnect the water heater and rotate it so the heating elements are accessible.
Usually when a heating element is bad there will be a lot of lime/calcium to flush out anyway.
USA case law on Home Inspection rwand1 Canadian Inspectors 10 5/24/09 12:30 AM
Mobile Home Water Heater ppendley Plumbing Inspections 0 4/24/07 8:09 PM
Mould inspection saves the day! gmendes Canadian Inspectors 37 11/18/06 11:51 AM
Common Defects List by Age of House trausch Inspection Education & Training 10 6/12/06 5:52 AM
