I had a plumber answer this question today but I thought I would post it here to see if I was the only inspector that didn't know.
Each photo is taken in the same house currently under construction. Why is there a screw in each drain? |
Damn if I know Gary....water level for gravity test?
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
I don't know either, but will guess is/was to hold the test ball so it don't fall in if deflated.
Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Keep pop cans and dirt out also to stop some one from Peeing in them .Screw is to keep the cap on so they can not lift it off.
... Cookie.. What do I win ? Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Roy, is that a comment from someone's experience in doing that?
You would not have done that yourself would you? ha. ha. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Two way street we helped each other all the time . ...Cookie .......... Of course what else would you expect me to say to a brickie Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Ok, we will say that the roofer did it. ha. ha.
Dale...no wonder you are the USA member of the year. They install one drain with a long header to hold a certain amount of water pressure for a hydro test. They put the screw through the remaining drains so they can break the vapor lock that can occur prior to proper venting being installed. Remove the screw and the drain vents.
Anyway....that is what the plumber told me. |
| Do you test floor drains? | jwortham1 | Plumbing Inspections | 10 | 10/4/07 3:57 PM |
| Two condensate drains combined into one? | jfunderburk | Inspecting HVAC Systems | 2 | 8/22/07 8:52 PM |
| Over flows (rim drains) | jcahill | Plumbing Inspections | 7 | 7/20/07 8:01 PM |
| After today..I may begin to do things differently | tneumann | Plumbing Inspections | 11 | 3/10/07 6:26 PM |
| Drainage & Grading | dmacy | Structural Inspections | 10 | 2/15/06 7:18 AM |
