Has anyone heard of any change regarding the drip leg required for the natural gas supply attachment to an appliance such as a boiler, furnace or water heater?
| Find an InterNACHI certified California Home Inspector (and anywhere else in North America) |
Some areas do not require it .
We just had a thread on this subject. Common sense says it is a good idea though. Go here...http://www.nachi.org/forum/f20/drip-leg-question-43738/ www.chicagopropertyinspection.com www.elliotthomeinspection.com www.chicagolandhomeinspection.com www.homeandcondoinspector.com www.homeandcondoinspection.com http://www.homeinspectorpro.com/ (Report Software) Bob Elliott http://www.chicagolandhomeinspector.com/ Last edited by belliott; 10/21/09 at 4:20 AM.. |
I believe the appliance installation instructions would also be a good source to check on this. some manufacturers require one
Check with your utility company.
This was a recent topic that caused me to do some research. I've gone over more than 50 different installation guides (for water heaters and furnaces) to see if I could get a consensus from the manufacturers as to their requirements. Indeed, there are many manufacturers that require drip legs on their appliances. As it turns out, there are just as many that make no mention of drip legs or sediment traps in their installation instructions. There are also those that defer to local codes, and others that state there "should" be a drip leg/sediment trap. As such, I have changed my reporting and will recommend these as an "upgrade," unless I know for a fact that it is required by the manufacturer. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
What does the IRC say.
Chuck Lambert is a non-member guest and is in no way affiliated with InterNACHI or its members.
From 2003 IRC Section G2419 (40
G2419.2 (408.2) Drips G2419.3 (408.3) Location of Drips G2419.4 (408.4) Sediment traps They are required. Chuck |
| Main Line vs. Supply Line Reporting Details | sshockley | Plumbing Inspections | 2 | 6/14/09 4:07 PM |
| HELP! What do you call a 3 prong male plug with a cord. | gromicko | Electrical Inspections | 5 | 1/9/09 1:33 AM |
| Size of supply line | aobrien | Inspecting HVAC Systems | 7 | 1/2/07 1:40 PM |
| Gas line & Supply Line | thejnicki | Plumbing Inspections | 2 | 9/13/06 10:24 AM |
