Old 3/29/07, 5:34 PM
Scott Schultz Scott Schultz is offline
Please Note: Scott Schultz is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Drip legs
Is there a spot in which a main drip leg might exist so that each appliance (water heater, furnace, etc..) wouldn't need it's own? Is a drip leg only needed if the pipe is above the appliance? I've seen a couple of furnances without drip legs but the gas pipe ran underneath the furnace and connected to the flex gas line which ran upwards to connect to it. Just trying to understand a little better when i don't see them why that is. thanks
Old 3/29/07, 5:53 PM
tdietrich1's Avatar
Default Re: Drip legs
This help?
http://www.nachi.org/forum/archive/i...hp/t-3285.html
tom
Old 3/30/07, 2:12 PM
Joe Funderburk, CMI's Avatar
I no longer call out their absence because the code enforcement people here don't think it's a big deal. It's not enforced at all by our local AHJ unless it's an industrial installation. The local gas company has no problem with their absence in houses. For me, it was a pain in the rear.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 3/30/07, 3:16 PM
The line runs under the furnace...
at the point where the line runs up to the furnace a drip leg should be installed, replacing the elbow--IF a drip leg is required by the local utility company.
Old 3/30/07, 7:08 PM
Matt Berman Matt Berman is offline
Wink Re: Drip legs
A drip leg may or may not be required in your area,but they do serve a purpose.The drip leg can catch any loose pipe filings, pipe dope,cutting oil ,moisture and anything else that could get into the gas valve.I always recommend they install one.Matt.
Old 3/30/07, 7:16 PM
Joseph Hagarty,  CMI's Avatar
Drip legs are generally required by the gas appliance manufacturer.
Absence of drip legs are noted on every report where applicable.
Joseph P. Hagarty, CMI
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 3/30/07, 9:35 PM
Peter C. Russell's Avatar
I note drip legs as a safety issue, a cheap one at that, to protect the appliance.
Old 3/31/07, 8:46 AM
homebild homebild is offline
Drip legs are only required where the presence of 'wet gas' exists. The presence of 'wet gas' is determined by the utility company alone.
Drip leg nbhi Plumbing Inspections 4 6/5/07 12:00 AM
Hidden Drip Leg ? rnewman1 Plumbing Inspections 2 9/27/06 5:40 PM
Condensate in the Drip Pan Skip Erwin Inspecting HVAC Systems 4 7/20/06 12:45 PM
Lack of aluminum drip edge Brenda Exterior Inspections 26 6/16/06 8:28 AM
