gmelien is a non-member guest and is in no way affiliated with InterNACHI or its members.
Had a call from someone that just had there home inspected. There inspector told them
"That the two water heaters could be plumbed in series to improve efficiency. (one tank set low, like 25c, the other set to 56c). He said that they would have been plumbed in series by the builder, and he's wasn't not sure why these ones are in parallel. Now it my understanding that dual water heaters are supposed to be plumbed in parallel. Am I wrong here? Thoughts .. opinions, please |
| Find an InterNACHI certified Washington Home Inspector (and anywhere else in North America) |
I guess it would all depend if they service two separate circuits or one.
If it is one circuit, they should be in series. If there are two circuits they must remain in parallel. I had one yesterday where they had one electric water heater and one gas-fired water heater in series. The house was to small to require 100 gallons of hot water. In this set up, they could shut off the gas water heater but not the electric. I recommended that if they did not need 100 gallons of hot water in storage they should have a plumber install a bypass valve so they could use the gas water heater by itself. With the electric water heater down stream, if you shut it off you get 50 gallons of cold water before the hot water arrives at the faucet. Turning off the upstream water heater (if they are the same) has no effect on operation, but will save energy loss by not storing unnecessary amounts of hot water. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Try this Greg. http://www.inspectapedia.com/plumbin...provement9.htm |
Thank you David and Brian!!
Series has an advantage I think. A shower becomes increasingly cooler because the hot water that is used from the water heater is replaced with cold water at a rate faster than the water heater can heat it up. By putting a water heater in between the cold supply and the other hot water heater, you can warm the cold water first so that the final water heater need only heat up already-warm water. This series scenario could potentially be setup where you would never run out of hot water while only paying for the energy to "warm" the water of the upstream tank.. and only paying for the energy to "heat" the already-warm water of the downstream tank. So it isn't quite the cost of keeping two tanks hot like you would have to do if they were parallel.
One should note that in predominantly colder climates, it doesn't matter anyway. The energy loss from heating up water on a parallel system that isn't immediately used doesn't disappear. It is lost to the air eventually, which someone is paying to heat anyway.... and besides, tanks are super insulated these days. Turn off your water heater, go on vacation, come home and feel the water... it's pretty warm. Most of the heat loss is suffered in the piping to the fixtures.
. This could be a great idea it the electric heater was the upstream and gas down stream . Nick is correct heat is not lost from water heater for about 8 months when we heat our homes . Roy Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
John Caraway is a non-member guest and is in no way affiliated with InterNACHI or its members.
If I installed two 50 gallon tanks in parallel, during times of low usage could I not turn off the water to one and just let the pilot burn (or turn off the gas as well). Oh, also turn off the hot water outlet. Then, when I've a houseful of people using three showers I could just reconnect and fire up the second of the heaters.
Any problems with this plan? All thoughts are appreciated. jc |
There is a community in this area (Malvern Hunt)
The townhomes all had (2) 75 Gallon Gas Fired Water Heaters - Water Heater 1 / Master Bathroom only. - Water Heater 2 / Kitchen and remaining Bathrooms & Laundry Parallel or series makes no difference. It depends upon the design intention. Obeserve and note accordingly. Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
You must keep the main water at 120 F if not you will have a chance of building bacteria in the tank. If you plan to use a tank in series this is OK but not parallel.
140 F is recommended in areas critical like Hospitals,Bath areas and Schools. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
Max Tap temp is 120° F I think that is now Ontario code . My tap temp is 108°F and tank temp is 140°F http://antiscald.com/prevention/legi...s/hotwater.php Roy Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. Last edited by rcooke; 12/6/11 at 11:01 PM.. |
Here is temperature info about the survival of the legionella baterium, which can cause the legion or pontiac fever:
You'll find pretty much the same info as what Roy posted if you go to this: http://en.wikipedia.org/wiki/Legionellosis Where there is a Will there is a Way! Will Misegades TREC# 10465 RedFish Home Inspections www.redfishinspections.com |
Thank you for your comments. I hadn't thought of bacteria. What if the "off" tank were drained during periods of non-use? What problems would you anticipate there?
jc |
| Need a home inspection in Washington? Check out InterNACHI's listing of Washington certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
That could put the temp about 35 to 46 °C (95 to 115 °F): Ideal growth range 20 to 50 °C (68 to 122 °F): Growth range If I was going to leave water in the tank then I would add about a pint of Chlorine ... Roy Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
As a non-member I want to thank you all for allowing me to use this forum. I received valuable advice and information.
jc |
| Water heaters in series | bhartley | Plumbing Inspections | 2 | 8/11/08 11:23 PM |
| Need Help On Chimney Liners | Nick Scibetta | Exterior Inspections | 13 | 1/11/06 9:53 PM |
