Old 9/7/08, 7:32 PM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is offline
Default Duel on-demand water heaters
Saw this today. 2 on demand water heaters hooked in parallel, not series. (meaning one or the other, not one to another) the idea here is, if the first one isnt cutting it the second one kick on. Problem is, the hot water will run, and when it switches, there will be up to 2 minutes of cold water. A little annoying when you are taking a shower. Looking at the plumbing, there seems to be no mixing valve. I wondered if they shouldnt be in SERIES, perhaps with a 5 degree temperature difference to prevent the second one from working too hard when it doesnt need to. What do you guys think?
Old 9/8/08, 12:09 AM
Terry Clayton Terry Clayton is offline
Default Re: Duel on-demand water heaters
wondering would not the water be pulled through both as if it was running as one i don't see how they would determine which would lead and which would lag. series sounds better but don't see how it could tell what temp to turn on they are operated with water flow correct.
Old 9/8/08, 1:51 AM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
Neither is a good practice. Instead isolate fixtures and use 1 for one group and the other for the second group. In practise they have a tendency to both operate unless set at grossly different temps.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 9/8/08, 8:56 PM
i wonder if a mixing valve would work. Take a little from each.
Old 9/8/08, 10:47 PM
jkogel jkogel is offline
Besides being a plumbing nightmare, I don't see the sense in running 2 heaters. If one is inadequate, install a bigger one, or install a small storage-type heater in series with it.
Old 9/8/08, 10:50 PM
rshuey rshuey is offline
Please Note: rshuey is a non-member guest and is in no way affiliated with InterNACHI or its members.
I think there should be a iNachi literacy course. "Duel" heater system, eh?
Old 9/9/08, 7:39 PM
Parallel heaters are often installed because the flow from this type of heater is relatively low. I have two such heaters in my basement, but they each serve a different part of the house. However, there is crossover piping to allow for one heater being out of service (has happened twice in 18 years).
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
"Garage" heaters in a store.... glarin Canadian Inspectors 2 8/26/08 12:12 PM
Another reason to recommend CO testers rnewman1 Interior Inspections 2 10/12/06 7:47 AM
