"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com Last edited by nbhi; 7/8/08 at 8:41 AM.. |
Call a plumber.
Is that a Okum-Lead joint? It almost looks like the cast is rotted at the joint, but if not you could reseal the joint with okum & lead if you know how...I have done it many times YEARS ago--- Probably the easiest would be cut that portion out and use two calder couplings after a new ABS cleanout is installed with ABS stubbed from each end of the cleanout. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
okum and plastic lead will work or snapping the cast and intalling PVC with fernco adapters.
Rick Kie |
| State law compliance reminder! We've made it easy to comply with state licensing laws | gromicko | Legislation, Licensing & Legal Issues for Inspectors | 0 | 12/20/07 12:35 PM |
| Canadian Customs is making it easy for vendors to bring samples to our Convention. | gromicko | Canadian Inspectors | 0 | 1/30/07 2:20 PM |
| Beware to all home buyers: an EASY Inspector is like The "EASY" GIRL in High School! | msyster | General Inspection Discussion | 37 | 8/4/06 7:04 PM |
