Kevin Luce is a non-member guest and is in no way affiliated with InterNACHI or its members.
I would like to here your thoughts on this.
I was wondering if anyone writes up the 3 foot clearance from the gas regulator and any electrical connection that can ignite that gas. If you don't call it out, why not. It only makes sense to me that you do no want electric next to something that has the potential to release natural gas into the air. Gas Meter Clearance National Fuel Gas Code 54-5.7.2.3 “Gas meters shall be located at least 3 ft. from sources of ignition.” Ignition is considered anything that can ignite gas, such as electric motors, switches, outlets and most exhaust/vent terminations such as furnace and/or dryer vent. 3 foot clearance also applies to windows that can be opened and/or crawlspace vents. |
Gas meter yes, gas regulator no.
Bill Corbett C.H.I. Magic City Inspections LLC InspectingtheUnexpected.com
Agreed. I don't make up my own standards.
When I talked to the local gas company years ago, we talked about the three foot clearance needs to be from the item that can ignite gas and the port where gas can be release from.
If you know that your local AHJ has such a requirement in addition to the meter itself, then you probably should note that in your report.
Should a gas regulator vent be piped to the exterior? In commercial applications it is required.
It is required around here.
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 77 | 5/10/12 6:13 PM |
| Battery Recall - Milwaukee Electric Tool Co. | pabernathy | Electrical Inspections | 3 | 7/12/07 10:08 AM |
| Square D Files Lawsuit to Prevent Counterfeiting | jtedesco1 | Electrical Inspections | 2 | 5/26/06 6:36 PM |
| Electric rates go up! | darnold1 | Electrical Inspections | 3 | 4/28/06 3:06 PM |
