hspinnler is a non-member guest and is in no way affiliated with InterNACHI or its members.
It was reported that the pipes in attic had once froze. owner wrapped these yellow pipe warmers around the pipes. The warmers are operated with a wall switch and must be switched on by occupant when needed. Question - wouldn't it be better to wrap insulation around the warmers? Does anyone have a link to a manufacturer? thanks in advance.
Hank---Google, Heat Tape.
Dang Dale. I did and opened up a Pandoras Box of information. Of particular interest is what the CPSC has to say about the product: http://www.cpsc.gov/cpscpub/pubs/5045.html
For example, replace uncertified heat tapes over 3 years old. Plug into a GFCI. Insulate only if advised by manufacturer. I'm in GA and do not come across many installations, so I have alot to learn. By the way, thank you for the help in Structural thread regarding floor tolerances and the UPC. Regards, |
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 36 | 10/27/10 11:21 AM |
| Help - Polybutylene Pipes | Rick G | Plumbing Inspections | 39 | 2/12/09 9:16 AM |
| Identify ABS defective pipe | mcyr | Plumbing Inspections | 6 | 1/29/09 7:39 PM |
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 72 | 3/12/08 12:19 AM |
| vent pipe in attic | brepanshek | Inspecting HVAC Systems | 2 | 3/6/07 3:32 PM |
