Old 6/1/07, 4:42 PM
Scott Schultz Scott Schultz is offline
Please Note: Scott Schultz is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default electric water heater
A GE electric water heater stated "total wattage - 4500/3308" The instruction manual stated that for 240v 4500w, the breaker is 25 amps. For 208v, it's 30 amp. Do I say that the breaker should be 25 amps cause it's a 240v circuit or do i say the installed 30amp is ok cause the heating elements run at 208v? thanks
Old 6/1/07, 4:48 PM
Roy D. Cooke, Sr's Avatar
Default Re: electric water heater
30 amp breaker is fine 240 volt heater on 208 will just be a little slower .If this is a home I would not be concerned.
Old 6/1/07, 7:32 PM
208Volts is a 3-phase service distribution panel.
Can someone tell me why a home would have such?
Roy is correct, you can run a AC/DC Welder on 208, but the amperage setting will have to be set higher than it would be at 240 volts.
Marcel
Old 6/1/07, 7:49 PM
Marcel
I have never seen a 208 volt system in a home in Canada.
I expect the manufacture just put two voltages on the name plate .
This unfortunately leads to some confusion with many people .
The Water heater is single phase so it does not care as long as the voltage is not above 240 volts.
Old 6/1/07, 10:01 PM
Marc D. Shunk's Avatar
Banned
Do they serve condo units at 120/208 in Canada like they so often do in the US? A condo or high-rise is where you'd normally expect to find 208 in a dwelling unit.
Old 6/1/07, 10:08 PM
We do not have a lot of Condos in my area but any I have seen are 120/240 volt.
I have often though how great it would be to have 208 in the home one more wire and 50% more power.
Must be a reason but I have no idea why not.
Old 6/2/07, 8:45 AM
Paul W. Abernathy's Avatar
Another thing you have to remember.......if the system is truly 120/240V then you can't use a 208V breaker in the panel....the line to line would be 240V and the breaker is only listed for 208V.....
if the breaker is listed 120/240V then you are fine but if the breaker is a 120/208V then it is not supposed to be in that panel enclosure...IF the panel inclosure is a 120/240V listed panel....and the voltage you are dealing with is truly 120/240V and indeed not 208V....
Sorry...that gets a bit cryptic but you know what I mean.......if breaker is a 208V rated breaker and the line to line potential is 240V then the breaker has to be rated for 240V line to line.....
Paul W. Abernathy,CMI,CPI,CME
Old 6/2/07, 9:05 AM
Michael Larson's Avatar
There may be some confusion here.
If I read your post correctly it is a residential WH being supplied by 240 VAC. The installed OCP is 30 A and therfore exceeds the mfgs. recommended OCP of 25 A when supplied by 240 V.
Old 6/2/07, 9:24 AM
Mine was just educational Michael...in regards to reading breakers ratings...seemed like a nice educational moment...lol
If the manual says install a 25A breaker...I would install a 25A breaker.....
Old 6/2/07, 9:30 AM
Paul,
Absolutely!
Your always educational and a great NACHI asset.
Now apply some ice to your head to prevent swelling.
Old 6/2/07, 9:49 AM
hell man.......I am so humble...CRAP sits higher on the plain of life than me and my swelling head.....but it's all good.....wife reminds me everyday what I am...(sigh)....
Old 6/2/07, 9:55 AM
Wives are way too good at that. I know mine is.
Old 6/5/07, 12:18 AM
Michael,
The manual for the water heater stated....
240v - 25 amp breaker
208v - 30 amp breaker
I'm thinking that the line itself is 240v but the heating element may be 208v? wasn't sure, but this particular house had a 30 amp breaker installed in the panel and since I've never seen 208v, assumed it was a 240v(like everything else is) and said to change the breaker to 25.
Old 6/5/07, 6:20 AM
Michael,
Scott, the heater element is probably rated in watts so a different breaker is required for protection depending on input voltage.
You did the right thing in calling out the need for a change.
Help. What is the correct way to report a breaker that is too big. gromicko Electrical Inspections 72 3/12/08 12:19 AM
Solar water heating + electric water heater Todd M. Soper Plumbing Inspections 20 5/30/07 7:31 AM
Venting an oil-fired water heater mh718 Inspecting HVAC Systems 3 11/16/06 10:36 AM
TPR & Combusiton Air thejnicki Plumbing Inspections 16 9/18/06 9:55 PM
