Do electric water heaters need to be at a height of 18" as well? I sure the answer is yes, but I thought I would ask yall before I write it up.
| Need a home inspection in Wisconsin? Check out InterNACHI's listing of Wisconsin certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Uh....no. They don't.
Why are you sure...or why would you even think...the answer is "yes"? Start with thinking about exactly what part of the water heater is required to be 18" from the floor and when. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
One must be aware of the reason behind a code, before one can elaborate further.
Make suggestions based on code, plus common sense. |
Thanks Bob - That is why I asked.
Not busting your chops as much as showing my reasoning when writing reports.
Required 18" is in garages for gas heaters only. P.S (has nothing to do with water)(all about flammable gases) |
And that which can ignite them.
Now, if the electric WH was set-up like an old electric range, with the heat elements exposed and underneath the tank, I would say yes, 18 inches is necessary. Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Perhaps you guys should explain to Chris under what circumstances a gas water heater in a garage would NOT need to be raised.
IRC P2801.6 Water heaters installed in garages (note that this is in the plumbing section, not the gas fired appliance section). Quote:
R202 Ignition Source Quote:
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX Last edited by cevans; 5/7/10 at 2:25 AM.. |
Your interpretation would require all electrical receptacles to be elevated at that same height, as well, in addition to any other permanently installed electrical device, such as freezers. That is not what the code is addressing, here. If it were, the same code would not forbid your scenerio and still allow for the FVIR gas heater to be placed on garage floor. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
G2408.2 Elevation of Ignition Sources (fuel gas section) specifically addresses the issue relative to gas fired appliances (e.g., gas fired water heaters) and includes the exception for appliances listed as flammable vapor ignition resistant. We can agree to disagree and we can agree to disagree with the standards, but the standards are what they are. The 18 inch standard in garages is not restricted to water heaters nor is it restricted to fuel fired appliances. The topic is addressed specifically in at least three separate sections of the IRC. This is not accidental. Not directly related but I came upon this tidbit of Darwin's theory at work while looking for a real life example. A little humor to keep it light Quote:
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX Last edited by cevans; 5/7/10 at 2:19 AM.. |
I stand firm that an "ignition source" (pilot and burner) is different from a "potential ignition source" (spark from an electrical receptacle, electric heating element in a water heater, etc) and the IRC is addressing open flames and sparks intended to ignite them, which is why this requirement is in the Mechanical and Gas codes (as you pointed out) and not the Electrical code portion of the IRC.
You can warn your client about anything you want, since codes do not restrict home inspection reports, but I would never write up an unelevated electrical water heater in a garage as being defective. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Last edited by jbushart; 5/6/10 at 10:44 PM.. |
My point was that the answer was not so simple and straight forward as you indicated and for a TX inspector such as Chris your reply is downright wrong. From the TREC SOP for Texas Real Estate Inspections (emphasis added): Quote:
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX Last edited by cevans; 5/6/10 at 11:55 PM.. |
I agree Chuck...
You're right. TREC requirements were not considered in my answer. I was wrong. Sorry.
While I defer to your TREC requirements, I still disagree, however, with your IRC interpretation. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Last edited by jbushart; 5/7/10 at 9:25 AM.. |
While debatable because of ambiguous wording (imagine that) even the 2006 IRC Commentary on this subject supports Chuck's interpretation in my opinion. It's not just a TREC thing.
| Whirlpool Electric Water Heater | bhartley | Plumbing Inspections | 2 | 4/20/07 9:41 PM |
| Water Heater Dip Tube Failure | jacaron | Plumbing Inspections | 2 | 2/24/07 11:28 PM |
| Venting an oil-fired water heater | mh718 | Inspecting HVAC Systems | 3 | 11/16/06 9:36 AM |
