What would cause this excessive rust on the gas line? There is a CSST gas line for the direct vent fireplace attached to the line.
Thanks! Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
| Find an InterNACHI certified North Dakota Home Inspector (and anywhere else in North America) |
Black iron pipe rusts easily when exposed to moisture. This is why it is usually painted if located in an area where it may be exposed to the elements. This pipe appears to be in a basement type location. From the picture, all the other materials appear clean. If the environment is not excessively moist and you have verified that leaks are not traveling down the pipe from the exterior, condensation or other potentials, you may want to consider that the this is how it was installed. It is not uncommon for fittings to come off out of the plumbers truck this way (Food for thought).
That is excessive?!
Naw!!! "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Thanks!
| Slope of waste drain line. | mlong | Plumbing Inspections | 5 | 4/23/08 10:54 PM |
| Selected Electrical Incidents and Occurrences - First Quarter | pabernathy | Electrical Inspections | 0 | 12/2/07 2:43 PM |
| Light Bulbs- All Ya Wanna Know | pabernathy | Electrical Inspections | 9 | 4/18/07 8:22 PM |
| TPRV line and condensate line marriage | ccarrington | Plumbing Inspections | 3 | 4/29/06 8:59 AM |
