Concerning expansion tanks on water heaters. In anyone's experience do they actually prevent damage to water heaters or is it more that in theory a water heater could be damaged if the tank was not present. Yes, they are required but in a house where water is being used constantly do they really solve a problem or is this a case of code gone overboard? Secondary question does anyone know when the national plumbing code started to require them?
Keith Runquist, CMI |
| Need a home inspection in North Carolina? Check out InterNACHI's listing of North Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
bdoles2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Not sure when the code went into place. |
Expansion tanks really are used to prevent backflow into the public water system. In my opinion over kill. Installing an expansion tee will do the same thing.
The codes are not well enforced in my area so I do not know. |
2) Expansion control is not to prevent backflow. Instead, thermal expansion control is required whenever the house is a closed system (and the water cannot back up into the municipal water system). “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
I talked with the chief plumbing inspector for charlotte nc for a long time about this.
They do not require one if the water pressure is ok at the time of their inspection. This of course could change but that was the answer last year. If the house has a hot water circulation system it will have some check valves so a thermal expansion tank is very necessary. Many houses can have no hot water usage during the period where a colder tank is reheating and get very high pressures. If something is going to blow apart it will most likely be a pipe, fixture, toilet line, washing machine hose or fridge water line. An old water heater could blow but newer ones are not the weak link in most houses. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Battle of the CMI's.
So debate as to whether they are installed or even needed. Fun debate.
For those that have these installed, do you inspect them for failure? Just asking. Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
Checking the air pressure would be hard on most since they are typically wrapped in insulation not to mention the fact that you have to turn off the water valve and drain the pressure off. Regular home maintenance item even though very few homeowners do anymore than paint, clean gutters and replace filters. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Most of us take a reading on the water pressure. His method is to install your pressure meter on the drain for the water heater. Turn the dishwasher on, run the faucets and bath until about half the tank is used. Not hard to do. Once the hot water is run to that point, turn off all fixtures and take your pressure reading. This should be the normal static pressure of the system. After 20 minutes or so, the hot water should be replenished, check your reading again. If the pressure has increased more than 8-10 pounds or more, the unit is bad and should be replaced. Sure it is beyond the SOP, but if I am taking a pressure reading anyway, why not just leave the gauge on a little longer and see if there is a problem? Comments? Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
Not a bad method and I may start doing that as these units around here get more age on them. It does leave the possibility of showing "good thermal control" when it may be bad. Possible things that would give a false test: Toilet plumbed with hot water, toilet flush valve leak causing water usage that keeps the thermal expansion from showing up. Someone turning on a hot fixture when you did not know it. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Yep. You need to make sure that nobody uses a fixture during the test that would relieve any pressure.
The plumber also said you could just open a faucet for a short time and then turn up the thermostat on the water heater. Same results. Just don't forget to turn the thermostat back down.... Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
Good article Nick. All correct. But what I'm asking is the expansion tank really a needed item or is it code overkill? I'll continue with code etc. for inspections but personally I see overkill and wonder what others have seen in the field. I'm especially interested if ther are any plumbers out there with field experience with expansion tanks or lack of them.
When they put a Back Flow device and or Regulator on the water supply to the house, and you have Copper or CPVC Piping then yes they are needed.
| Closed plumbing systems & expansion tanks | jfunderburk | Plumbing Inspections | 31 | 1/4/12 2:21 PM |
| Roof Deck Seams Visible - What's Wrong? | psullivan | Roofing Inspections | 35 | 11/30/10 1:22 AM |
| Potable Water Expansion Tanks | inxil | InterNACHI & RealMatcher Blogs | 1 | 4/9/09 12:05 AM |
| Please proof this article: An Overview of Water Heater Expansion Tanks. | gromicko | Plumbing Inspections | 5 | 3/30/09 2:54 PM |
| Pressure regulators and expansion tanks | rray | Plumbing Inspections | 22 | 9/20/08 12:22 PM |
