This is new construction. Location of water heater is a laundry room. Seems to me the gas line is begging to be damaged. Is this a problem? A C-word violation by chance?
Various AHJs around my area do not allow flex to connect 'non-movable' gas appliances.
Other than that, I don't know. Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
jwisecup is a non-member guest and is in no way affiliated with InterNACHI or its members.
hey,if ya put a nail thru one side you could hang your clothes up on it
ok, maybe thats a badddd idea! |
And I would recommend protection from physical damage. |
It would be too long for my AHJs. They limit gas flex lines to four feet.
Is that CSST flex piping (e.g. TracPipe) or jacketed solid coper? What did the markings on the pipe read?
Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
CSST (not the same) follows the same general rules as rigid steel piping (galv or black). Although, the CSST pictured was certainly not supported properly. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Yes, it was CSST. I said it was improperly supported in the report.
Thanks to all. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Here is one for you Joe. I knew the bend was too sharp, and was able to read on the tag the the radius should not be smaller than 1 1/2". They even added " about the size of a golf ball".
Yours, Brian, is an appliance connector, which is not the same as CSST. Installation requirements are much different.
Here is another picture of CSST. Although they appear similar, they are quite different. . . IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Yes, CSST and appliance connectors...different. |
You are telling me when the make the miles of sst flex tube at the factory they have a special run for appliance connectors? |
Appliance connectors are factory made, listed assemblies, which are not allowed to be modified. They are made in specific lengths and are not allowed to be connected to additional appliance connectors. They are, exactly what they are - appliance connectors - made to connect gas fired appliances to gas supply lines. CSST is a piping system. Manufactured in bulk lengths and generally fabricated in "the field" as needed. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
My experience is flexible SST tube comes from a handful of giant tube mills. The flexible SST tube than goes to different manufactures to get made into their finished or manufactured product.
I understand that the supply piping and the service whips have different applications, to me they are very similar in nature. You make an excellent point though Jeff, that they are indeed different, as are their applications, and should be treated as such. I can easily get off track. |
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 77 | 5/10/12 6:13 PM |
| Gas flex line in crawl space | Richard Seay | Plumbing Inspections | 19 | 8/12/08 8:12 PM |
| TPRV line and condensate line marriage | ccarrington | Plumbing Inspections | 3 | 4/29/06 7:59 AM |
| Massachusetts Board of Registration of Home Inspectors | jtedesco1 | Legislation, Licensing & Legal Issues for Inspectors | 0 | 2/14/06 3:38 AM |
