jmichalski is a non-member guest and is in no way affiliated with InterNACHI or its members.
Has anyone else experienced this problem with this model of faucet? This is the second time I turned the tub faucet on to check operation and it froze in the "full on" position. I had to shut off the main and I offered to wait for the plumber to arrive both times, but the sellers and their agents absolved em of responsibility.
Both times, I was told afterward that the tub had not been used for several months or possibly years. Is this a known flaw in this style faucet? Or am I doing something wrong? |
Could be due to age, it could also be due to mineral build up which dislodged when turned on, or an O-ring problem?
I have that exact style. Is was here when I bought the place 8 years ago and have never had a problem with it.
It could even be a copper spur that has found its way into the stem cartridge.
I have some photos of the cartridge at this thread
http://www.nachi.org/bbsystem/viewto...?p=99296#99296 Hope it helps. |
Today I found the same faucet model but the problem was that it there was no hot water flow. The knob was not engaging the hot water valve.
It's not that I have problems with it every time, but it seems that the age or lack of use has something to do with it. I asked both realtors for the description of what the plumber fixed so I know for future use to ask about frequency of use and issue some warnings.
Thanks for the feedback. |
Joe,
I have seen the same issue with those valves, basically they are junk. |
| Fetch Report problem | mhazelwood | Miscellaneous Discussion for Inspectors | 7 | 11/12/07 12:12 PM |
| Is MAC a problem | bemelander | General Inspection Discussion | 2 | 9/6/07 12:34 PM |
| Plumbing problem at home. | mnahrgang | Plumbing Inspections | 25 | 7/10/07 6:32 PM |
| Compression Faucet Leak | Rachel Johnson | Plumbing Inspections | 9 | 7/1/07 1:57 PM |
| Very tough problem | Albert Detorre | Inspecting HVAC Systems | 7 | 2/23/07 1:01 PM |
