| Find an InterNACHI certified New Mexico Home Inspector (and anywhere else in North America) |
The valve is not allowed to drain uphill. . .
Yes then they connected to a 3/4 drain pipe with other tprv s from other condo.s Just one drain and i have no idea where it dumped.
Last part should not matter as they will not go off at the same time.
Yea but if one is leaking, how do you tell which one?
That may sound right but its not.
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
I am comparing it to a breaker with electric heat baseboards and a window A/C unit on the same electrical branch.
(allowed) Got a code? because I would not call it a hard write up when I am lucky to not see them dumping into a drain pan most of the time. |
504.6 Requirements for discharge piping. The dischargepiping serving a pressure relief valve, temperature relief valve or combination thereof shall: 1. Not be directly connected to the drainage system. 2. Discharge through an air gap located in the same room as the water heater. 3. Not be smaller than the diameter of the outlet of the valve served and shall discharge full size to the air gap. 4. Serve a single relief device and shall not connect to piping serving any other relief device or equipment. 5. Discharge to the floor, to an indirect waste receptor or to the outdoors. Where discharging to the outdoors in areas subject to freezing, discharge piping shall be first piped to an indirect waste receptor through an air gap located in a conditioned area. 6. Discharge in a manner that does not cause personal injury or structural damage. 7. Discharge to a termination point that is readily observable by the building occupants. 8. Not be trapped. 9. Be installed so as to flow by gravity. 10. Not terminate more than 6 inches (152 mm) above the floor or waste receptor. 11. Not have a threaded connection at the end of such piping. He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
I figured that was the rule, but wonder why?
Just a guess, but maybe because if one of them discharges you can't tell which one is failing?
How would you know other wise? Not like there is an alarm at the bottom of the drain |
There could be... http://www.getfloodstop.com/category_s/2.htm
Well I wrote it up do to the fact is going down then up and connected to a drain no air gap
When like this Typicial Tprv should be in a down ward slope and have a air gap going to the drain to prevent back flow , Recommend a Licence Plumber to review to see if this meets local requirments. |
| Tprv | gscheer | Plumbing Inspections | 15 | 6/19/08 12:58 AM |
| TPRV questions | Rick Maday | Plumbing Inspections | 1 | 8/23/07 1:51 AM |
| TPRV drain piping | tsmith5 | Plumbing Inspections | 4 | 1/11/07 11:25 PM |
| TPRV drain | cbuell | Plumbing Inspections | 1 | 1/5/07 9:22 PM |
| TPRV line and condensate line marriage | ccarrington | Plumbing Inspections | 3 | 4/29/06 8:59 AM |
