Would this be an approved fitting to use for cooper and plastic? This was leaking but it was at the soldered connection.
| Need a home inspection in Tennessee? Check out InterNACHI's listing of Tennessee certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I think it is call a push connect, they do make them . I would just write it up to repair the leak and go on from there . Was there any more used
Yes, by the laundry. Those were leaking big time but not at the fittings.
Supposedly Fannie May fixed the plumbing, But I do not think so. One pic is behind the beautiful cabinet concealing portions of the piping. Told client to direct that finishing to the trash. |
LOL got to love that kinda of stuff.
I just refer all to a License Plumber Looks like it needs a make over lol Wayne Wilson East TN Home Inspections LLC Knoxville, Oak Ridge, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-1490 http://site.myhomeinspection.net |
Based on your photos alone, it's hard to know if "approved" because no markings are visible.
"P2608.1 Identification. Each length of pipe and each pipe fitting, trap, fixture, material and device used in a plumbing system shall bear the identification of the manufacturer. P2608.4 Third-party testing and certification. All plumbing products and materials shall comply with the referenced standards, specifications and performance criteria of this code and shall be identified in accordance with Section P2608.1. Where required by Table P2608.4 ["supply system components" is in the table], plumbing products and materials shall either be tested by an approved third-party testing agency or certified by an approved third-party certification agency. Commentary: This section has been revised to require that all plumbing products and materials comply with the referenced standards....Additionally, the code has been revised to include specific requirements for third-party certification and testing of plumbing products. Table P2608.4 lists these requirements. “Third-party certified” indicates that the minimum level of quality required by the applicable standard is maintained and the product is often referred to as “listed.” ...Although the code does not specifically state the identification or marking requirements except for the manufacturer’s identification, the applicable referenced standard states the minimum information required. The identification or marking requirements typically include the name of the manufacturer, product name or serial number, installation specifications, applicable tests and standards, testing agency and labeling agency. Commentary Figure P2608.4 [below] shows an example of a typical label for PVC plastic pipe." ![]() P.S. It's important to note that "tested" does not mean the product passed the test. If you simply see a manufacturer label saying "3rd party tested" you could dig deeper and ask for documentation indicating it passed. In this case, however, a 3rd party certification is actually required. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Looks like all copper and maybe crimped. Need more info. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Looks like the right color to me. Clean your glasses perhaps??
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
I've got Shark Bites caps that I carry. None of those are copper like in the photo. I also don't see the plastic ring that would be present on those or push connect. Most likely crimped like Michael said.
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
Micheal is probably right , I could not see to much from the picture . Lon and short it is leaking at the copper side so it will have to be replaced .
Is it a Pipe Thread Fitting?
Are you color blind or just blind?
How many fingers am I holding up? You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Thanks Bruce, appreciatte the link.
Oh i was right lolol Thanks Bruce
Most likely a attempt at it anyway . Should be sealed .
| Plastic Whitely Gas T Fitting | pbennett1 | Plumbing Inspections | 5 | 5/19/09 9:54 PM |
| new plastic fitting | bking | Plumbing Inspections | 4 | 8/20/08 8:05 AM |
| Yep, The plastic Nail | mcyr | Structural Inspections | 6 | 3/23/08 10:53 AM |
| Gas changes for plastic vents in Canada | rcooke | Canadian Inspectors | 0 | 7/30/07 2:15 PM |
| plastic piping? | Scott Schultz | Plumbing Inspections | 5 | 3/28/07 1:40 AM |
