Old 3/16/06, 4:06 PM
Tab M. Wilcox Tab M. Wilcox is offline
Please Note: Tab M. Wilcox is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Flex Gas Connector
Does anyone know when the IRC and the NFGC started to prohibit running flex gas lines through cabinetry? I did an inspection recently where this condition was present. I wrote it up as a safety hazard and that a solid gas pipe needed to be installed to the furnace valve assembly that extended through the cabinet for the flex to connect to. The HVAC company that installed the equipment stated that this was allowed when they did the install (approximately 2 years ago), but that they would fix it if I could show them the code. The AHJ was using the 2000 IRC at the time of construction. I know this sounds like I'm trying to enforce code, but the HVAC company is trying to make me look bad with the Realtor. I have called the AHJ and they are little to no help. Thanks
Old 3/16/06, 4:47 PM
Michael R. Boyett's Avatar
Default Re: Flex Gas Connector
2003 IRC G2422.1.2 Appliance fuel connectors: Connectors shall have an overall length not to exceed 3 feet........ Connectors shall not be concealed within, or extended through, walls, floors, partitions, ceilings or appliance housings. A shutoff valve......blah, blah
Old 3/16/06, 4:48 PM
Ted Allen Ted Allen is offline
Flex line is not allowed to pass through the cabinet. I call it no matter how old the home is.
Sorry I do not have a code for you.
I am sure someone will post the applicable code for you.
Old 3/16/06, 4:57 PM
Thanks for the replies! I have the 2003 IRC code book and was aware of the 2003 IRC G2422.1.2 Appliance fuel connectors section. What I need is when was this brought into the IRC or NFGC code cycles. Thanks again!
Old 3/16/06, 5:01 PM
Jeffrey R. Pope's Avatar
The listing of the appliance connector has never allowed these restricted conditions.
Have them show you otherwise.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Gas flex connector to furnace jcahill Inspecting HVAC Systems 25 7/24/07 7:22 PM
Nice Report on AL Wire Terminations - Enjoy pabernathy Electrical Inspections 0 7/2/07 1:35 PM
Flex duct used for exhasut flue. jlybolt Inspecting HVAC Systems 11 4/6/07 12:04 AM
Gas and oil hot water tank and Boiler Share Vents hvanderbeek Miscellaneous Discussion for Inspectors 8 1/25/07 6:22 PM
surface yellow gas flex piping? Coral Inspecting HVAC Systems 16 12/22/06 3:43 AM
