Old 5/14/10, 3:02 PM
pnarron pnarron is offline
Default Flex Gas Line
Is a flex gas line ok in attic if is just laying on top of joist and covered up by blown in insulation?
Need a home inspection in Oklahoma? Check out InterNACHI's listing of Oklahoma certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/14/10, 4:08 PM
Richard Hyland Richard Hyland is offline
Default Re: Flex Gas Line
Phil
It must be installed in accordance with the manufactures requirements. Most requirements are all the same. Here is one.
http://www.tru-flex.com/HVAC/docs/17482_TF_TrainingG15.pdf
Chief
Old 5/15/10, 6:04 AM
Brian E. Kelly's Avatar
Yes, as long as it is supported per the manufactures specifications
Replace flex gas line connectors? jcahill Plumbing Inspections 7 1/3/10 10:05 AM
Flex gas line through solid walls???? rjack1 Plumbing Inspections 7 4/8/09 11:06 PM
Gas flex line in crawl space Richard Seay Plumbing Inspections 19 8/12/08 8:12 PM
Yellow gas flex line run... jonofrey Plumbing Inspections 8 8/12/08 5:01 PM
