Flexible LP gas line through walls. Can anyone tell me if they know who manufactured this flexible gas line? I found a six year old modular home with the flexible line being run throughout the home. My concern is running flexible gas lines through solid walls. Any ideas?
| Find an InterNACHI certified Alaska Home Inspector (and anywhere else in North America) |
Can't make out the manuf. It's probably printed on the opposite side. It can run through walls and floors, but has to be protected if it penetrates anything with a sharp edge, like a fireplace box. Here's a common manufacturer where you can download installation instructions. http://www.gastite.com/homepage.php?pg=home
You know about the bonding requirements for CSST, right? If it's yellow, it was probably in the lawsuit and requires a bond. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Good stuff. Very common in modern construction.
IRC 2006 G2415.2 Concealed piping shall not be located in solid partitions and solid walls, unless installed in chase or casing.
James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas. |
Since it is stamped iapmo here is their site.
http://www.iapmo.org Gerry Pallotta Alota Home Inspection Services www.alotahomeinspect.ca Greater Toronto Area Home Inspector Mississauga Home Inspector |
Yes but I don't think these would be SOLID walls or partitions.
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
| New Flex Line!! | bhartley | Inspecting HVAC Systems | 1 | 3/4/09 7:03 PM |
| Flex gas line | bhartley | Inspecting HVAC Systems | 4 | 2/4/09 9:31 PM |
| Gas flex line in crawl space | Richard Seay | Plumbing Inspections | 19 | 8/12/08 9:12 PM |
| Yellow gas flex line run... | jonofrey | Plumbing Inspections | 8 | 8/12/08 6:01 PM |
