Nathan W. Swilling is a non-member guest and is in no way affiliated with InterNACHI or its members.
Should a gas dryer have a flexible hose for the final hookup (like a gas range) or should it be solid piped all the way to the dryer?
It seems like you might want some flexibility, for example if the washing machine next to the dryer were to "walk" and bump dryer over a bit. Is there a code requirement here? |
Manufacturer instruction require it for proper install.
http://www.appliancesdirect.com/Inst.../003675838.PDF |
Appliances should be attached to the gas piping with a listed appliance connector. There are exceptions, but most codes require appliance connectors at all appliances.
The instructions seem to be requiring that the hose from the gas hookup to the appliance be a flexible hose rated for gas. Are they specifically requiring that you use a flexible hose?
In other words, are you pretty confident that the codes forbid someone using only hard piping between the gas feed and the dryer? |
Since we do not deal specificaly with code , I would suggest it as a good safety precaution.
A dryer has lots of vibration and I do know for a fact that it is required in California as I saw that while looking at info for you. Is there easy access to the unit.? What is the material transition.? Black pipe to Brass? Arre they the proper looking bushings and connectors. Can they disconnect the dryer vent and clean it without needing a pipe wrench? Look it may or may not be code near you , but common sense suggests a flex connector in most cases.At least in regaurd to a movable appliance. How can you level it ? |
Bob;
In our area, stoves, dryers and other movable gas appliances MUST be connected with listed flex (stainless, with either a yellow or gray (older) plastic covering). Water heaters, furnaces, and other non-movable gas appliances MUST be connected with black pipe (they don't allow copper around here). You should take the People's Energy course. A whole lotta good info. Hope this helps; Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Will ,I am sure you did not mean to come across as condensending. I am here to help Nathen.
.I am aware of the course you mention, but not sure how it helps Nathen. Is Nathen subject to Chicago area code? I do not see an indication of where he is from. Chicago requires a smoke detector be 15 feet from the bedroom door , yet you recommend them in the room do you not. Chicago code has nothing to do with the subject of this thread. My advise stands as good advise. The subject is Gas Dryer. Last edited by relliott; 3/27/08 at 2:23 AM.. |
Sorry if I came off that way. Not my intention.
Sorry, "flexible connector".
Will
No problem buddy, you have always been a big help.and my business is growing. Having a big week. Nathan sorry to get off subject. |
That I can believe as I used rubber hose on my glass torches for 20 years with no problems.
Our local gas conveyance co. and every other that serves mid US that I have checked (18 so far) require a flexible connection to a unit that can be moved. Units that are stationary must be connected with iron pipe. The flexible connector must be rated for the specific application.
In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
Okay, the plumber said the reason for the hard pipie is that a dryer moves too much. According to him, the dryer could move too much and cause the flexible connector to fail. A stove is moved infrequently and therefore the hookup wouldn't be strained.
Personally, this explanation sounds ridiculous. If a dryer moves so much that a flexible connector would fail, wouldn't a hard connection CERTAINLY fail? Any plumbers out there who can comment? Unfortunately, it looks like he's going to be reluctant to change it. |
| Dryer sheets potential hazard | badair | Miscellaneous Discussion for Inspectors | 15 | 7/9/11 3:39 PM |
| Maytag 110 Us dryer hookup in China | Chad Doering | Electrical Inspections | 12 | 2/11/08 3:48 PM |
| What is a 'condenser' dryer ?? | rcooke | Canadian Inspectors | 8 | 9/9/07 8:02 PM |
| Dryer lint filter | senomoto | Miscellaneous Discussion for Inspectors | 6 | 5/14/06 11:01 AM |
| Bad Dryer and Bath Fan Venting | Jkrt00 | Inspecting HVAC Systems | 3 | 3/14/06 12:07 AM |
