| Plumbing Contains discussions about plumbing. |
Yesterday evening I did an inspection in which there had been some "weekend warrior" renovation done on the house. One of the issues was a water heater gas line which was evidently 1/2" outer diameter flexible copper piping, which ran along the floor, up a bit behind the unit, down almost to the floor alongsicde the unit, and up to a short length of proper rigid gas line to the controls.
Obviously this is an improper installation, and I told my clients the line should be run with rigid gas line with a "drip leg," and would get info as to how significant it really is. How big an issue is this, really, and why? It's not that all that difficult to correct, but the water heater appears to be working fine as it is, and I don't want to make a mountain out of a mole hill or gloss over a potentially dangerous condition. |
Copper runs to gas appliances is common here but there may be other issues and a picture would help. |
I do, but it's still on my camera. Evening inspection.
ckratzer is a non-member guest and is in no way affiliated with InterNACHI or its members.
Is this natural gas or LP ?
Call your local gas company and ask if copper is even allowed in your area.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ℠ Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I haven't had time to research this, but I'm pretty sure that this is a safety hazard, and that there is a chemical compound in gas that "eats" copper.
You're correct Keith. It's the hydrogen sulfide (the chemical added to give an odor to natural gas).
Copper piping is allowed for gas piping in areas where the hydrogen sulfide levels are low enough (less than .3 grains per 100 cubic ft.), but this varies by the supplier. CPC 1210.1.1 IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ℠ Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 9/21/06 at 12:07 PM.. |
Yes, found out that at least the newer copper is okay. Thought for a moment I had had a bad dream. Everyday I'm reminded how little I know.
Now this is getting really confusing. Newer copper or older copper? How much hygroden sulfide?
The copper line did not appear to be new. Definitely tarnished, but did not look very old. The gas company varies in my metro area. Just to further muddy the waters, how much an issue is the lack of a "drip leg" (bearing in mind the line slopes somewhat upward to the elbow)? |
Check with your local utility. They are best qualified to answer both of your questions. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ℠ Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Thanks, guys.
I have a very, very good nose for gas leaks, and none were detected. |
Laura Line is a non-member guest and is in no way affiliated with InterNACHI or its members.
question for ya
the yellow flexible gas lines are they ok? did an inspection today and there was a yellow flexible, meaning looking crimped line installed on the gas line, I know that in new construction they are using yellow flex lines, but this one was crimped looking not smooth like I've seen in new construction, It was installed by the owner and his brother |
Any pictures available? IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ℠ Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
http://www.toolbase.org/TechInventor...ntDetailID=741 |
Michael,
I have seen this type of connection on gas lines on new construction that you are showing here and it was not that type, in fact we had a bit of disagreement about the type you are showing and what I saw. I have never seen this kind I am trying to describe here before and sorry no pics, to me the line I saw yesterday looked and felt like plastic, it was yellow and it was crimped not smooth (like copper flex tubing that is crimped) I wrote down the part number it had on it #CSSD54-48 I know that the HWH was installed by the owners son and he wasn't sure where he got the line????? so just wanna be sure, since the listing agent was questioning me. thanks for the help |
| Water Heater Dip Tube Failure | jacaron | Plumbing | 2 | 2/25/07 12:28 AM |
| Venting an oil-fired water heater | mh718 | HVAC | 3 | 11/16/06 10:36 AM |
| TPR & Combusiton Air | thejnicki | Plumbing | 16 | 9/18/06 9:55 PM |
| Bathroom Shut-off Valves - Mineral deposits - Do you note them as leaking in reports? | jwatts1 | Plumbing | 8 | 7/29/06 12:50 PM |
