This wasn't from an inspection, but rather a question I was asked. Someone sent me this picture and asked me a question about this fireplace in their home. Obviously there is a leak at the fitting and looks to be cross-threaded. My question is about the flexible gas line. Does that fall under manufacturer's requirments of the insert? Are there any code requirements against flexible gas lines in the firebox?
John Safstrom TREC #10566 Systematic Home Inspections, PLLC Allen,TXwww.systematichomeinspections.com john@systematichomeinspections.com Last edited by jsafstrom; 10/28/11 at 2:01 PM.. |
| Need a home inspection in Idaho? Check out InterNACHI's listing of Idaho certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Fine like that
BUT NOT LIKE THAT!!! |
So one would follow the manufacturer rec's for gas supply piping for the gas logs or the insert itself?
John Safstrom TREC #10566 Systematic Home Inspections, PLLC Allen,TXwww.systematichomeinspections.com john@systematichomeinspections.com |
They are similar in use of 1/2 inch blackpipe through the knockout with an 18 inch 3/8" flex (stainless) |
thanks Bob
That brass thread is striped on the threads of the black iron pipe according to what your picture shows.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 Last edited by kwood; 10/28/11 at 3:03 PM.. |
They have flames comming out of a gas line and they don't call a plumber ...
Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
An HI is a non-member guest and is in no way affiliated with InterNACHI or its members.
Isn't that the pilot light?
Flex in firebox can be OK for gas logs. Not OK if using wood to burn.
AND like the man said / CALL a plumber. |
you need a flexible line to accommodate whatever the distance from the gas line rough-in to the appliance.
Pete Campbell pete4545@comcast.net http://www.PortStLucieInspections.com http://www.ChooseGI.com http://ifwemissitwewillfixit.com Inspecting Fort Pierce, St. Lucie Village, Lakewood Park, Vero Beach, Indian River Shores, Sebastian, Fellsmere, Fort Drum, Okeechobee, Jensen Beach, Stuart, Palm City, Hobe Sound and Indiantown, Florida. |
For gas logs copper and aluminum tubing are also allowed in some areas and per the IRC
Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... Last edited by roconnor; 11/1/11 at 7:25 PM.. |
Love second picture. Tape or Liquid dope visible on flange fitting, dont see that on pipe fitting side. Home owner tried repair again and in wrong spot?
Can-Am Home Inspections Inc. Level 1 Thermography Specializing in Building Infrared Thermography ProLab Certified INACHI #09113003 IAC2 #01-8254 www.can-amhomeinspections.com |
Keith Silva is a non-member guest and is in no way affiliated with InterNACHI or its members.
So it is safe to use flex line in a gas fireplace that has a vented log set in it? My girlfriend just bought a new log set for her gas fireplace and the gas inlet on the new set is on the right hand side but the gas inlet into the fireplace is on the left. Is it safe for me to run a flex line around and behind the pan that came with the set to the other side?
| Flexible gas lines | mthiltgen | Plumbing Inspections | 5 | 6/29/09 9:56 PM |
| Main Line vs. Supply Line Reporting Details | sshockley | Plumbing Inspections | 2 | 6/14/09 3:07 PM |
| Difficult Chimneys | thance | Inspecting HVAC Systems | 2 | 1/29/08 8:16 PM |
| Selected Electrical Incidents and Occurrences - First Quarter | pabernathy | Electrical Inspections | 0 | 12/2/07 1:43 PM |
| Need HVAC Pics! | hgordon | Inspecting HVAC Systems | 2 | 2/17/06 10:06 AM |
