Old 11/22/10, 9:06 PM
Richard W. Washington's Avatar
Richard W. Washington Richard W. Washington is offline
Default Flexible Gas Line Underground
The line was run underground from the meter to the back patio grill. Probably about 20'. Did not see any reference in the IRC that hard pipe must be used. The only reference I saw was that the line must be buried at least 8". Can it be flexible line?
Richard W. Washington, owner
RW Home Inspections, Inc.
www.RWHOMEINSPECTIONS.com
Texas Real Estate Commission (TREC)
Professional Inspector License #7238
Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter
InterNACHI member since 2004
Based in Katy, serving Houston and all surrounding communities
Need a home inspection in Kentucky? Check out InterNACHI's listing of Kentucky certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/22/10, 9:18 PM
James E. Braun, CMI's Avatar
Default Re: Flexible Gas Line Underground
As long as the line is approved for underground, but I am betting it is not. I have never seen a yellow colored underground rate flex line before. You definitely need to check into it. Underground flex line is used all the time in my area.
Old 11/22/10, 9:43 PM
Christopher Currins's Avatar
This brand, WARDFLEX, says it may be installed underground with non-metallic conduit. But the ends should be sealed to keep out foreign matter and moisture.
Page 55 http://www.wardflex.com/images/design_install_guide.pdf
Christopher Currins
Certified, Licensed
Old 11/22/10, 9:46 PM
Brian E. Kelly's Avatar
Same with Diamond Back. http://www.mtlfab.com/media/L1627.pdf
ACCEPTABLE USAGE
DIAMONDBACK™ CSST shall not be buried directly in the ground or directly embedded in
concrete. When DIAMONDBACK™ is to be buried in the ground or embedded into concrete it
shall be routed inside of a nonmetallic conduit such as schedule 40 PVC. The conduit must be
sealed at any end that is exposed to outdoor weather conditions to prevent water from entering.
It is recommended that the CSST be one continuous piece inside the conduit from end to end.
CSST mechanical fittings are not allowed or permitted inside the conduit.
Old 11/23/10, 2:21 PM
Sean Fogarty's Avatar
http://www.gastite.com/include/langu..._D+I_Guide.pdf
Here is the gastite brand instructions. They allow penetrations through wood, but must be protected through masonry. THey also manufacture a different covering for underground applications.
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Old 11/23/10, 3:41 PM
Joe Funderburk, CMI's Avatar
If you want to sound knowledgeable and professional in your reports, call it Corrugated Stainless Steel Tubing (CSST). If you want to sound otherwise, call it flex pipe, flex line, yellow pipe, etc.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 11/23/10, 3:51 PM
If you want to be knowledgable, then call the local rep. Many offer free classes and certifacations. I talked to the one for flextite since I was curious. He said they are having one soon. Only a couple of hours educational class. And then like magic wola you are certified...
865-256-5397
Old 11/23/10, 4:02 PM
"The WARDFLEX system described in this guide is intended primarily for interior use. See section 4.6.4.2 for specifics on outdoor applications. [That section speaks about connections to outdoor appliances.]
4.3.5 OUTDOOR ISSUES
General Provisions
WARDFLEX Mechanical Joint Fittings shall be protected from the effects of weather when used outdoors. After the connection is made to outdoor equipment the WARDFLEX Mechanical Joint Fitting shall be sealed by wrapping two layers of tape (e.g. PVC, Silicone) or by applying shrink sleeves (e.g. PVC, Polyolefin).
The following additional instructions regard the use of WARDFLEX in systems in which portions of the piping are exposed to the outdoors as required to make connections to gas meters or gas appliances,
which are attached to, mounted on, or located in close proximity to the building structure.
The external protective covering shall remain intact as much as practical for the given installation.
When installed along the side of a structure (between the ground and 6 ft.) in an exposed condition, the WARDFLEX must be protected inside a conduit or installed in a location which will not subject it to mechanical damage.
WARDFLEX shall not be buried directly in the ground or directly embedded in concrete (e.g. patio slabs, foundations or walk ways). When burial or embedment is required,WARDFLEX shall be routed inside nonmetallic (e.g.PVC) conduit. The conduit shall be sealed at any exposed end to prevent water from entering using double wrapped PVC tape or PVC shrink sleeves.
Theodore Roosevelt
Joe Funderburk, CMI
Old 11/23/10, 4:03 PM
Don't forget bonding requirements.
Theodore Roosevelt
Joe Funderburk, CMI
Old 11/23/10, 4:27 PM
Good stuff Joe. The gastite is allowed in all weather applications. Go figure.
865-256-5397
Help. What is the correct way to report a breaker that is too big. gromicko Electrical Inspections 77 5/10/12 6:13 PM
Flexible Natural Gas line thejnicki Plumbing Inspections 4 8/1/06 11:30 AM
TPRV line and condensate line marriage ccarrington Plumbing Inspections 3 4/29/06 7:59 AM
