Flexible gas supply line to Water Heater.
How do I determine if this kind of flexible gas line connecting to this hot water heater is appropriate? I’ve heard it can change from municipality to municipality.
Thanks guys!
I don’t see a problem.
It’s a simple gas appliance connector being used as intended.
Based upon** your** post, the only way you will know, is to check with your local AHJ.
