Old 7/27/06, 11:31 PM
thejnicki's Avatar
thejnicki thejnicki is offline
Default Flexible Natural Gas line
Question: Can a flexible gas line penetrate a fire seperation wall in a two story home.. Line was from the water heater it appeared to have stainless sheathing... Sorry no photo
Old 7/28/06, 12:02 AM
Jeffrey R. Pope's Avatar
Default Re: Flexible Natural Gas line
If it's CSST, then it is allowed. CSST can be installed in the same manner as rigid piping, although it requires additional support.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 7/28/06, 12:13 AM
Brian E. Kelly's Avatar
http://www.patternstream.com/Case_St..._catid19_e.pdf
Old 7/31/06, 12:18 PM
thejnicki's Avatar
Thanks guys, very helpful..
Old 8/1/06, 11:30 AM
Robert J. OConnor's Avatar
Model codes generally allow rigid/flexible metal pipe to penetrate a firewall if it's fully grouted or installed with firestopping. The stainless sheathing may be a firestop penetration sleeve for the pipe, where the space between the pipe and sleeve should be filled with firestop caulk (usually red in color). The idea is to prevent fire and smoke from passing through the penetration generally for at least the fire rating of the wall in hours.
See IRC R317.3 as a guide (local mileage may vary) ...
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Help. What is the correct way to report a breaker that is too big. gromicko Electrical Inspections 77 5/10/12 6:13 PM
Size of supply line aobrien Inspecting HVAC Systems 7 1/2/07 12:40 PM
Flexible copper 1/2" gas line to water heater -- how big an issue? fbartlo Plumbing Inspections 30 11/3/06 1:19 PM
TSSA Gas natural draft boiler notice rwand1 Canadian Inspectors 1 9/12/06 11:37 PM
TPRV line and condensate line marriage ccarrington Plumbing Inspections 3 4/29/06 7:59 AM
