Hmmm I wonder where the wash water is going? There is no lift pump. Rural property. Maybe it's watering a farmer's field?? Don't know how to describe this one.
Greg Liebig, Owner Sheboygan Wisconsin Home Inspector 4-Square Home Inspections, LLC Where Knowlege will put your Mind at Ease © Sheboygan, WI 53081 (920) 451-4646 www.4squarehi.com Follow Us on Facebook Follow Us on Linked-In |
| Find an InterNACHI certified Massachusetts Home Inspector (and anywhere else in North America) |
Perhaps to the old drain field?
"Never underestimate the difficulty of changing false beliefs by facts." |
That's what I'm thinking. I see this quite a bit with washers along with septic systems. The owners don't want to bleach out the septic system so they discharge the bleach water to the surface water "somewhere else"
Somtimes older properties can't pass current perk test standards so when the replace or upgrade the septic system they end up with a mound at a higher level above the slab. Of course the best solution is to provide a pit and lift station but that does add to the cost. You might be able to find evidence of a previous 4" line going into the slab. Good luck. "Never underestimate the difficulty of changing false beliefs by facts." |
| Make $50.00 More Profit per Inspection with Septic Tanks | ebeahm1 | Ancillary Services & Additional Topics | 6 | 8/20/09 2:38 PM |
| 10 years of septic system backups lead buyer to file suit | gromicko | Ancillary Services & Additional Topics | 0 | 5/6/08 1:27 PM |
