Question - I've seen this type of venting 3-4 times a month in older houses and never had anyone complain. The bottom metal flue is the 80% furnace with an uphill rise from it to the newly lined masonry chimney (stainless steel liner). The upper metal flue is the water heater with an upward slope from it till right before the chimney - then it turns down to drop into the furnace flue and they become 1 flue entering the chimney.
My question is - I've not worried about this before but recently started wondering something ........ We always say we need a 1/4" p/ft uphill rise on flues, so do you think the downturn of the water heater flue will cause backdrafting of the water heater. |
| Need a home inspection in Arkansas? Check out InterNACHI's listing of Arkansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Sorry forgot the picture in my previous post
Possibly. Anything that defeats the means of exhaust getting out of the building properly can lead to backdrafting. By any means, that set up is not right and needs correction.
UPC 511.2.9 says that the wye shall be considered as part of the common vent and 511.2.12 says that the rise is measured from the draft hood to the centerline where the two vent gas streams come together.
In that regard, you do not have a continuous rise and it should be considered defective, IMO. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
This venting is incorrect, any horizontal run in the vent should slope upward (never downward) at least 1/4" per foot. Correction is needed.
It might work fine But it is wrong . Write it up if it gets fixed great if it does not get fixed and some one dies You should be off the hook .
I call this out every time I see one . CRA Cover Roy's A $$.. Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Absolutely incorrect....repairs are needed.
Tim Wendorff Triple B Home Inspection, LLC www.triplebhi.com 262-224-4420 A Southeastern Wisconsin home inspector specializing in residential home inspections and radon testing! |
It may let condensation "roll" down furnace flue pipe.
That's what HVAC tech said caused this. Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
Braun Inspection Consultants Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
Come on, Dan. Youse should have seen this before. I have seen it dozens of times. HWH should be at a good slope, under the furnace flue. Those old Brookside homes are tough to inspect.
CMI, CPI, KS #0110-0094 Termite #16601 KS Radon #KS-MS-0027 BBB A+ Accredited Business Serving the Greater Kansas City Metro Area Eastern Kansas/Western Missouri http://www.metrospeckc.com "If opportunity doesn't knock, build a door"--Milton Berle |
Regardless this type of Post Teaches the newre Homie what to look for .
Thanks Dan .. Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Another makeshift shortcut way of doing things.
A little close to the PVC pipe isn't it? Call it out. Good one Dan. Gas and Oil Appliance Venting Gas fireplaces are factory-built systems. The manufacturer’s listing and instructions will preclude attaching any other appliances to it. Multiple gas or oil furnaces or boilers, as well as hot water heaters, can be vented into one flue. There are a few rules to mention:
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
| Oversized Water Heater Flue? | krigler | Inspecting HVAC Systems | 14 | 2/19/10 1:05 PM |
| Coming soon. Free, online, fireplace and chimney inspection course. | gromicko | General Inspection Discussion | 15 | 12/14/09 4:19 PM |
| What's Inside A Chimney | mcyr | Inspecting HVAC Systems | 14 | 9/17/08 6:11 PM |
| Minimum slope for water heater exhaust flue? | kshepard | Inspecting HVAC Systems | 13 | 6/13/08 1:12 PM |
