Old 12/5/08, 11:43 PM
Alexandra Baxter Alexandra Baxter is offline
Please Note: Alexandra Baxter is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Flushing pipes with acid?
I have a question and I don't know where else to find answers- this past summer my sister was taking a shower. Plumbers were downstairs doing repairs/remodeling, and we can't figure out what happened, but she was later found in the tub with burns covering 70% of her body. Doctors believe they're chemical burns, but something went wrong with the water heater and the pipes burst the next day, flooding the downstairs area.
Is it normal for pipes to be flushed with corrosive chemicals ie hydrochloric acid? I can imagine pipes would have been turned off first? And if pipes are flushed, how much is typically used?
Any information would be incredibly helpful.
Old 12/6/08, 12:22 AM
Darren Spencer Darren Spencer is offline
Default Re: Flushing pipes with acid?
Is the downstairs part of your home or is it an apartment?
Professional plumbers use power snakes to clear drains but if it is a floor drain I have seen them use a crystal treatment to control tree roots; very rare.
Have you checked with the plumbers as to what was done?
Were they handymen or licensed plumbers?
Old 12/6/08, 12:44 AM
It is a 3 story home, and the accident happened on the 2nd floor. This happened in the Middle East where my family was living at the time- in Dubai, and the landlord has refused to cooperate. The police are so incredibly slow and unhelpful as well.
We've given up on filing suit or pursuing a legal investigation, but we're looking for answers for personal closure.
The chemical shot out through the showerhead in a short burst, but just enough to burn one side of her face and her back. It looks like it was a thick liquid, since the burn lines are straight and there are no drip marks. Hope that helps..
Old 12/6/08, 1:04 AM
Charley L. Bottger's Avatar
Alex there should be no form of acid used to clean domestic water lines acid is some times used but not recommended in drain lines but never domestic water lines. In countries outside the U.S. one would not know what they use
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 12/6/08, 1:09 AM
cfuoco's Avatar
cfuoco cfuoco is offline
Please Note: cfuoco is a non-member guest and is in no way affiliated with InterNACHI or its members.
It is possible that the water was heated through a coil and because of the composition of the water (hard water) the inside of the pipes was becoming restricted (buildup). They might have cleaned out the coil with an acid that is supposed to loosen the restriction in the pipes and did not flush the lines properly.
Old 12/6/08, 1:16 AM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
Wish I saw this earlier.
I was having a discussion with a client about hydrocloric acid,and yes it will burn your skin and yes many non -professional plumbers use it.
Were you home at the time and did the air smell like rotten eggs when they were working?
Old 12/6/08, 4:05 AM
Dominic J. Maricic's Avatar
Dominic J. Maricic Dominic J. Maricic is offline
Send a message via ICQ to dmaricic Send a message via AIM to dmaricic Send a message via MSN to dmaricic Send a message via Yahoo to dmaricic
What if they were using sulfuric acid to clean the drains? That could have shot up from a lower shower couldn't it? I've seen that used on drains and it practically explodes. It would also cause chemical burns to skin. Maybe it wasn't the shower head it came out of.
2008 InterNACHI Member and Innovator of the Year
HOME INSPECTOR PRO HOME INSPECTION SOFTWARE
NOW ONLY $499 ($15O OFF!!)
Easy to use, customizable Home Inspector Software that runs on Windows, Mac & Linux
InterNACHI members receive 3 months of FREE home inspector website hosting
List yourself in our Home Inspector Directory Free
Watch our NACHI.TV Software & Search Engine Optimization videos!
Help@HomeInspectorPro.com
Old 12/6/08, 10:31 AM
David A. Andersen's Avatar
In the US there are devices and procedures to prevent cross contamination of the water supply.
These procedures and devices obviously were not used in this case.
Also is does not have to be acid. There are other chemicals that burn.
The main issue was that the water supply was contaminated and not properly purged if done intentionally.
This is one of those dangers when living in another country.
I have seen all kinds of crazy things that would never be allowed in this country.
I was poisoned two times by washed food, and a friend almost lost an arm because of the water in South Korea.
A good thing that you didn't drink the water!
BPI# 5015804
Old 12/6/08, 6:34 PM
Robert- Her friend who found her in the bathtub has said the bathroom smelled like burning meat/rotten food, which led me to immediately think sulfur when she told me.
And Dominic, whatever came out of the pipes came must have come through the showerhead, as her legs and feet were left untouched.
I truly appreciate everyone's responses!
Old 12/6/08, 6:49 PM
relliott's Avatar
Terrible situation and if it invoves a court suit,an inspector could probably determine where or how it could have been introduced if true.
There would also be residue.
As you stated it occured in another country.
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 9:16 AM
What are these pipes? hmcbride Plumbing Inspections 5 7/30/07 4:44 PM
green pipes jmaisano Plumbing Inspections 11 11/7/06 12:59 AM
Water supply pipes and drain pipes running through return air ducts? aharper1 Inspecting HVAC Systems 3 9/26/06 1:09 PM
