Old 5/25/11, 10:43 PM
Jeffrey R. Pope's Avatar
Default Functional Drainage
For about ten minutes, this bathtub was draining really well - and then I opened the access panel inside the closet
functional-drainage-20110525_24_01.jpg   functional-drainage-20110525_25_01.jpg
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Need a home inspection in Kansas? Check out InterNACHI's listing of Kansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/25/11, 10:59 PM
Bob Elliott's Avatar
Default Re: Functional Drainage
Damn overflow tube.
Did you damage the ceiling below?
Looks like you have a sink back to back with that thing judging from the galvanized supply I see but I hope it was on a slab.
There must have already been damage if they were using that tub.
Old 5/25/11, 11:13 PM
Jeffrey R. Jonas's Avatar
And you are concerned with filling shower pans to 2 inches depth.
(Couldn't help myself, as you rarely give us a chance to 'rib' you)!
Old 5/25/11, 11:15 PM
Previously a bank-owned property, purchased by an investor - fresh paint, new carpet fixtures, sinks, etc., etc. - now selling to my client. Slab-on-grade with back to back bathrooms.
Besides the overflow being disconnected, the drain line was obstructed, which is why the water is pouring out. It didn't cause any damage anywhere as it was just free flowing beneath the slab. I never did see any water outside...
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 5/25/11, 11:16 PM
I was actually thinking of that post when I saw this
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 5/26/11, 12:59 AM
So was I but figured I would wait for someone else to say it in a funnier way.
Old 5/26/11, 11:01 AM
David C. Macy's Avatar
David C. Macy David C. Macy is online now
I need to break my habit of running the water first and then looking at then drainage piping. Yesterdays house was missing the disposal and water was leaking all over, glad I had some rags.
I always try to check the slab on grade homes at the bath access areas, I also lift the floor registers to check the inslab ducts as most are dirty, some have water, insects.
Old 5/26/11, 1:23 PM
I always check below sinks as soon as I turn on the water, and again within a minute or two.
I open access panels "when I get to them" during the normal course of the inspection. I may consider changing that protocol.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 5/26/11, 1:46 PM
Brian E. Kelly's Avatar
Old 5/26/11, 2:39 PM
No need BK. It drained out beneath the slab
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 5/26/11, 2:42 PM
Must have been one heck of a (concealed) crack in the slab!
Site grading and drainage wdevries Canadian Inspectors 5 10/6/09 10:23 PM
Options in selecting materials for basement construction wdevries Canadian Inspectors 2 8/4/08 1:30 PM
gutter downspout to basement drainage system David Paterson Exterior Inspections 2 12/18/06 6:27 PM
