dbucknavich is a non-member guest and is in no way affiliated with InterNACHI or its members.
What is the remedy for bad flow, if lets say if you turn a sink faucet on while the shower is running and the flow almost stops? The toilet would completely stop flow.
A plumber would need to find the problem before he could remedy the situation. Is this just limited to the bathroom? Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
A tap not all the way open in the line ,like the main feed. a long run, A restriction like a kink , Galvanised Pipe and it is amost closed inside. Many reasons , If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
Both upstair bathrooms were weak. Pressure at the main shut off was around 70. Welcome back Dale.
I have a pressuer reducer in my home and only run 45 lbs but am close to the supply and have 3/4 feeding the home . If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
If mains pressure is around 70 psi I would suspect partially blocked supply pipes. On older properties ot is not unusual to see both copper and Galvanised Iron piping that is very restricted by scale build up, also some newer homes with poorly filtered well systems will fur up quickly. BTW, for reference, you will also loose around 4-5 psi per floor of rise as well, so if your supply is at 70 comming in you should expect to see 65 on the first floor, 60 on the second, 55 on the third and so on. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
5lbs per floor, I can wrap my head around... (kiddin' ya Roy.. - Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
People look at me at an Inspection and say WOW! you sure have a lot of knowledge. I say yes and much of it is useless and this gets a chuckle. </IMG></IMG> If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
| efficiency of 15 yr old peerless | afrost | Inspecting HVAC Systems | 11 | 11/19/07 10:51 AM |
| Septic Systems | Rick Sovastion | General Inspection Discussion | 28 | 7/31/07 10:55 AM |
| Pressure and flow rate | rbennett | Plumbing Inspections | 4 | 10/2/06 9:56 AM |
| Functional Flow and Drain | scosta | Plumbing Inspections | 4 | 4/7/06 5:26 PM |
