Does anyone have a table that lists the gallons per minute (assumed) of the plumbing fixtures of a home? I'm starting to do septic load inspections, and need to be able to calculate the amount of water I'm introducing into the system.
Thanks in advance. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
| Find an InterNACHI certified Nevada Home Inspector (and anywhere else in North America) |
bump. Anyone?
Mark,
I realize this isn't exactly what you're looking for, but maybe it will offer some info you can use... http://www.toolbase.org/PDF/DesignGu...umbingcode.pdf Jeff Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
for proper accuracy you will have to measure each fixture's actual flow which depends on pipe sizes, water pressure...
http://www.inspect-ny.com/septic/Sep...ter_Volume.htm http://www.mde.state.md.us/assets/document/ResAudit.pdf The water audit spreadsheet is a useful tool to evaluate water use in the home. ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
I don't what your asking for is practical Mark.
There are so many different faucet types. Example: A typical brass laundry sink faucet is wide open but a lav or kitchen sink haves a aerators and are much lower flow rate fixtures. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
It's understood that individual fixtures will vary, but it's accepted that this type of math is acceptable for doing the calculations that are required. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
How about a stop watch and a gallon jug Mark.
I have to ask this one , Why would you need to know this?Is it going to be a design type thing? or a existing tank and field?
You could alawys turn everything on check the gallons used at the meter if it is on a well installed a flow meter |
That would work, but take too much time in an already very time consuming inspection.
I was told by the instructor (who wrote many of the state policies and procedures) that there was a table that listed this information that we could use. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
I need to know it, because it is a state law that a stress test of a certain number of gallons needs to be put through the system. It's for existing systems. The meter would work assuming it is there and assuming it is functioning properly. Two assumptions that will only hold for a certain number of inspections.
grusk is a non-member guest and is in no way affiliated with InterNACHI or its members.
Mark; hope something in one these links help
Septic Systems Understanding Your Septic System http://www.inspect-ny.com/septic/septadds.htm http://www.toolbase.org/PDF/DesignGu...umbingcode.pdf http://www.montana.edu/wwwated/septic.htm http://www.agnr.umd.edu/users/wye/pe...er/septic.html http://muextension.missouri.edu/webs...additives.html http://www.egr.msu.edu/age/aenewslet...loudon4_05.htm http://www.extension.umn.edu/distrib...es/DD7439.html http://www.rideau-info.com/local/sep...ow-buried.html http://www.kentcountydpw.com/septic_tank.htm Septic Load and Dye Test Poll http://psma.net/dye_tests http://www.inspect-ny.com/septic/Sep...ter_Volume.htm http://www.mde.state.md.us/assets/document/ResAudit.pdf Gary |
I am not a engineer but there is no way of being exact , It depends on pressure which would be up and down. So average would come in to play. My thought would be size of line, amount of fixtures . Then there is a problem if the septic system has been maintained . What if the septic lines are partiality plugged? I have a flow meter i use to test for wells and yes it is only approximate . i would think if you sized the main water line 3/4 or 1/2 inch for flow
I know you probably have this but just in case http://flexpvc.com/WaterFlowBasedOnPipeSize.shtml |
"It's not what you believe that matters...it matters what you believe!" |
| For your viewing pleasure, we just opened up the Table of Contents to all... | gromicko | Miscellaneous Discussion for Inspectors | 4 | 7/3/08 9:18 AM |
| Max load allowed on 2x2 ledger | bking | Structural Inspections | 4 | 12/23/07 2:05 PM |
| Are these electrical training books worthwhile? | jtedesco1 | Inspection Hardware, Software & Publications | 10 | 12/5/06 6:07 PM |
