Old 1/15/12, 9:16 PM
Robert A. Jack Robert A. Jack is offline
Default galvanic corrosion?
Can anyone explain if this corrosion is a problem. I’m assuming it is a galvanic type corrosion. If not cleaned, can this result in a leak?
Need a home inspection in Wisconsin? Check out InterNACHI's listing of Wisconsin certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/15/12, 9:25 PM
Roy D. Cooke, Sr's Avatar
Default Re: galvanic corrosion?
Yes it will .
I would look for an electrical low voltage electrical leak .... Roy...
Possible DC
Old 1/15/12, 9:45 PM
Thanks Roy. I will recommend that.
Old 1/15/12, 9:52 PM
Michael Larson's Avatar
What?
They need plumber not some hack with a meter.
Michael Larson
Hudson, WI
Old 1/15/12, 10:38 PM
Charley L. Bottger's Avatar
Looks to me like the packing gland leaked until it scabbed closed seen a million just like it
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 1/15/12, 10:45 PM
Charley, I see copper galvy, black and brass in the pic.
Michael Larson
Hudson, WI
Old 1/15/12, 10:56 PM
I do see it also but look at the packing gland corrosion goes all the way to the hand wheel
NACHI Member
State License # 130
Old 1/15/12, 11:05 PM
Yep, but there is plenty to call out there.
Michael Larson
Hudson, WI
Old 1/16/12, 3:22 PM
Nick Gromicko's Avatar
http://www.nachi.org/galvanic-corrosion.htm
Find a Home Inspector
Old 1/16/12, 3:43 PM
I don't disagree with that but the green comes from a water leak guess we could talk about the super bowl that seems high on some threads
NACHI Member
State License # 130
Galvanic corrosion of a ufer ground kshepard Electrical Inspections 28 11/7/11 3:37 AM
Galvanic Corrosion. New InterNACHI inspection article. gromicko Plumbing Inspections 2 9/16/10 12:21 AM
Galvanic Corrosion dgagneur Inspecting HVAC Systems 4 9/13/10 10:41 PM
New article on galvanic corrosion inxil InterNACHI & RealMatcher Blogs 0 9/13/10 8:40 PM
Soldered pipe supports causing corrosion kshepard Plumbing Inspections 7 12/3/06 2:30 PM
