Old 3/24/12, 1:11 PM
John Graham, II John Graham, II is offline
Default Galvanized natural gas pipe
At an inspection the other day, I noticed a galvanized elbow installed between 2 straight runs of black iron gas pipe. Is galvanized allowed as a general rule? Does it depend on local codes?
Jonathan Graham
HouseCalls Home Inspection Services
Need a home inspection in North Carolina? Check out InterNACHI's listing of North Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/24/12, 1:37 PM
Michael Larson's Avatar
Default Re: Galvanized natural gas pipe
The issue with gavanized pipe is the possibility of the coating flaking and then plugging valves and orifices.
If drip/dirt legs are present the risk is low but I would note the non standard use of the galvanized fitting in the gas piping system.
As a Professional Home Inspector, I support the privacy of my clients.
For more information click Trustyourinspector.ORG
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
Old 3/24/12, 5:20 PM
Wayne B. Wilson's Avatar
Well for once we agree Micheal. I would note it, it should be changed . It does depend on were you are the do not even ask for drip legs here .
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 3/24/12, 6:49 PM
Cameron Anderson's Avatar
Cameron Anderson Cameron Anderson is offline
Please Note: canderson5 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Our local utility doesn't recommend it either(for the reasons Mike gave).
Old 3/24/12, 7:58 PM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
Allowed by the UPC...
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/24/12, 8:07 PM
Bob Elliott's Avatar
I was told not allowed here however if running underground to say a garage would you rather use Black or Galv ?
Old 3/24/12, 10:56 PM
Joe Funderburk, CMI's Avatar
And the IRC. It's a misconception that galvanized is prohibited for natural gas.
Theodore Roosevelt
Joe Funderburk, CBO, CMI
Angie's List Super Service Award Winner 2013, 2012, 2011, 2010.
Ph: 704-351-1776
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 3/24/12, 11:42 PM
Christopher Currins's Avatar
It varies at where you live.
From Ameren Illinois, my local utility provider:
Fuel Line:
Customer Requirements:
…… The customer’s fuel line is the pipe that connects
to the outlet of the gas meter set and extends
through the wall into the house. The fuel line
should enter the house or structure within three
(3) feet of the gas meter set.
…… The customer fuel line from the meter through
the house wall
must be a minimum of one (1) inch
IPS schedule 40 black iron pipe.
For Corrugated
Stainless Steel Tubing (CSST) installations, a
termination fitting mounted on the outside house
wall is acceptable for the transition from black
iron pipe.
CBC HOME INSPECTIONS
Christopher Currins
Professional Home Inspector In Edwardsville, Glen Carbon, Godfrey, Maryville,
Fairview Heights, O'Fallon and surrounding areas of S
outhern Illinois
We Make It Safer
Old 3/24/12, 11:54 PM
Fuel Line:
the house wall
For Corrugated
iron pipe.
I said IRC. Local codes vary.
Theodore Roosevelt
Ph: 704-351-1776
Old 3/24/12, 11:56 PM
2009 IRC G2414.4.2 (403.4.2) Steel. Steel and wrought-iron pipe shall
be at least of standard weight (Schedule 40) and shall comply
with one of the following:
1. ASME B 36.10, 10M;
2. ASTM A 53/A 53M; or
3. ASTM A 106.
Commentary: Steel pipe must be Schedule 40 or heavier, must comply
with one of the listed standards and can be black
iron or galvanized. Contrary to popular belief, natural
gas does not adversely react with the zinc coating on
galvanized pipe."
Theodore Roosevelt
Ph: 704-351-1776
Old 3/24/12, 11:57 PM
You also said this
"It's a misconception that galvanized is prohibited for natural gas."
Christopher Currins
outhern Illinois
We Make It Safer
Old 3/25/12, 12:00 AM
Fuel Line:
the house wall
For Corrugated
iron pipe.
Is galvanized prohibited anywhere else by your utility? Or just the fuel line?
Theodore Roosevelt
Ph: 704-351-1776
Old 3/25/12, 12:08 AM
It's not prohibited with water lines, if that's what you mean.
Not sure if it still is with All of the fuel line. It used to be, at least by local AHJ.
But I believe the fuel mixture has changed, so maybe have the restrictions.
I rarely see galvanized on fuel lines, unless it's a nipple, elbow, etc.
Christopher Currins
outhern Illinois
We Make It Safer
Old 3/25/12, 12:13 AM
Here's an example from a few days ago.
Christopher Currins
outhern Illinois
We Make It Safer
Old 9/8/14, 3:24 PM
paul dimaggio paul dimaggio is offline
Please Note: paul dimaggio is a non-member guest and is in no way affiliated with InterNACHI or its members.
As Joe Funderburk mentioned (which is the same requirement as 2013 California Plumbing Code, Fuel Gas Piping 1208.5.2.2), galvanized pipe may be used for natural gas piping.
3. ASTM A 106.
ASTM A53 specification. "Standard Specification for
Pipe, Steel, Black and Hot-Dipped, Zinc-Coated, Welded and
Seamless", section 17, discusses Galvanized Pipe requirements:
17. Galvanized Pipe
17.1 Galvanized pipe ordered under this specification shall
be coated with zinc inside and outside by the hot-dip process.
The zinc used for the coating shall be any grade of zinc
conforming to Specification B6. ...
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 42 11/3/13 7:47 PM
Help - Polybutylene Pipes Rick G Plumbing Inspections 45 6/26/13 5:21 PM
Pellet stove help chellickson General Inspection Discussion 23 8/19/10 2:23 AM
Is this allowed? belliott Plumbing Inspections 4 7/15/09 7:40 PM
Identify ABS defective pipe mcyr Plumbing Inspections 6 1/29/09 7:39 PM
