This over 100 year old home had poor water flow at the fixtures and wondering if galvanized water supply is the cause. Pretty sure it is, but want to be positive.
Need a quick answer on this if possible. Thanks. 774 Manor Road Staten Island, NY 10314 718-514-3393 |
| Need a home inspection in California? Check out InterNACHI's listing of California certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
mlopezi is a non-member guest and is in no way affiliated with InterNACHI or its members.
I would say YES
Yes it is
agreed
I carry a small magnet in my box so I can make that determination on the spot. |
Great! Thank you all. Can finish the report now.
And John, good idea about the magnet! 774 Manor Road Staten Island, NY 10314 718-514-3393 |
May I ask what type sub floor that is?
That's a wall Bob. The image is not properly oriented. Notice the ladders in the background.
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
Galvanized pipe was commonly used for water supply lines many years ago, but over time many have filled with scale, which is why some older homes suffer from low water pressure. Hard water greatly reduces the life of steel pipe. www.chicagopropertyinspection.com www.elliotthomeinspection.com www.chicagolandhomeinspection.com www.homeandcondoinspector.com www.homeandcondoinspection.com http://www.homeinspectorpro.com/ (Report Software) Bob Elliott http://www.chicagolandhomeinspector.com/ Last edited by belliott; 9/28/10 at 6:44 PM.. |
True
I always start by checking if hot and cold are the same. Remember to remove aerators. |
I write in my report that this is a possible cause of the poor flow, but also say that it could be configuration of the piping, types of fixtures, clogged aerators, etc, and refer it to a plumber to determine the exact cause.
I think it is galv. but has been painted over.
If private water it will be very rusted and pump may be the cause of pressue and rust depending on type |
| small valve on cold water supply ahead of water heater? | Walt Hoffman | Plumbing Inspections | 6 | 1/23/06 7:44 AM |
| Need Help On Chimney Liners | Nick Scibetta | Exterior Inspections | 13 | 1/11/06 9:53 PM |
