JohnH515 is a non-member guest and is in no way affiliated with InterNACHI or its members.
I inspected a manufactured home today and the garbage disposal operated by having the power cord come up through the counter top, then you would plug it in. I am calling this out as a defect. Am I correct? Also they had a double sink set-up, with 2 p-traps. Regardless of how they tie into the trap arm, I believe that is wrong. I am calling that out as a defect. Am I correct on that as well?
Thanks John |
double trapping is usualy a no no, but it's hard to tell with out a pic. as for the disposal, it wouldn't be hard to replace the outlet with a switch or switch/outlet, theN snake a line in the wall and mount an outlet in the cupboard and have it run off the switch only. not a good idea to plug in any device that calling for power before you even plug it in, let alone a disposal. your hand will be wet from doing dishes, need to clear the disposal reach out to plug it in and......WAMMO.
John Clayton is a non-member guest and is in no way affiliated with InterNACHI or its members.
Actually, all In-Sink-Erator brand garbage disposer you see sharing a trap with another sink compartment should be noted for improper installation. In-Sink-Erator installation instructions state to individually trap their disposers. Last edited by John Clayton; 2/28/06 at 12:38 AM.. |
John,
A) More than (1) P-Trap per fixture is incorrect and is most certainly a defect. Reason: If a large volume of water is released down the drain it can carry with it enough pressure and force to pull the water right out of the traps. Now.......it is fine to have lets say (2) combined fixtures share a trap if within a certain distance of it...like the old displosal and paired sink itself...and also (1) trap may serve up to 3 sinks.....provided the waste arms do not exceed 30 inches in length. B.) As for the disposal- Well playing some effect into it may be that it is a manufactured home and the NEC has some views on that...but without going into a lot of detail yes you should call it out as well.... Normally the disposal circuit is dedicated and can be fixed with a cord and plug assembly...however, it is usually devised to a dedicated receptacle under the sink controlled by a switch above....either way being under the sink and dedicated it would be exempt from GFCI....and moving it to plug into the counter brings in ratings issues on the dedicated circuit requirement and other factors....not to mention if being a live running load....waiting to simply be plugged in.... as jay stated....wet hands...overgrab the plug..fingers touch the metal plug arms.....could be a WILD one...and chances are the countertops are not even GFCI protected anyway....... Most certainly I would call both out.......one because it is totally wrong...and the other because it is potentially unsafe...either way protects you. Paul W. Abernathy |
Thanks to all who answered. I called out both issues. My gut told me both are, at the very least, questionable.
John |
Individually trapped sink compartments are perfectly legal and required in certain situations as long as they are properly vented, whether that be by individual vents or common venting or.... Common venting allows more than one trap or trapped fixture to connect with a verticle or horizontal drain before or at the vent connection. Quote:
John are you the guy from ESPN
Gary Porter GLP's Home and Mold Inspections 321-239-0621 Certified Commercial Mold Inspector Serving Orlando, Kissimmee, Winter Park, Winter Springs, Oviedo, Titusville, Celebration, Harmony, Avalon, Windermere, Deltona, Debary, Sanford Orange County, Seminole County, Volusia County, Osceola County www.homeandmoldinspections.com |
That is not what was asked...Yes. each can have its own trap.....you cant have (2) traps to one sink per say...that is what i was speaking of.
Also there i a difference in being incorrect and illegal...I did not use the term illegal... Paul W. Abernathy |
ahh......Illegal........versus Violation.....hmmm.....I try to stay away from defining those two together...
I would guess it is a violation until reported and caught...then illegal... I hardly think you will DO TIME....from a violation....more than likely fined for the violation.....hmmm...never really thought of it as illegal...lol.... Paul W. Abernathy |
Also.....way to much typing to go into ALL the exceptions and allowances for distances and so on........I would have to advice buy a Code Check if the poster wants EVERY requirement on it.
I only listed a synopsis.... Actually sounds like the poster knew the ruling beforehand...OH WAIT...wrong John...thehehe.......dang I hate that...lol Paul W. Abernathy Last edited by pabernathy; 3/1/06 at 9:45 AM.. |
Paul W. Abernathy |
Wow! I never thought this thread would get this much acton. It is true that I kinda knew that the double trap was wrong. The sink trap tied into the waste arm of the disposal trap. Since the sink trap did not direcetly enter the disposal trap, I thought there would be some kind of exception. While on the inspection, I mentioned the issue with the buyer, and said that she may need a plumber to re-work the drains (she said she wanted to get rid of the disposal.) I really dont care much whether its code or not, just trying to avoid that call later on, when she gets a plumber who bad mouths me for not reporting on the trap issue. I went with "may be incorrect installation" and explained what are downsides to double trapping and said "if these problems arise, a qualified plumber may be needed to correct". I hopefully educated my client, while protecting my butt. I have only done about 12 inspections on my own, and I'm still a little nervous. Hence my post. I belong to my local NACHI chapter, and once I recoup a little more of my business investment, I will be joining National. This message board is the GREATEST!
P.S - I am not from ESPN Thanks again to all John |
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 77 | 5/10/12 6:13 PM |
| Glade plug ins could lead to fires | gmendes | Miscellaneous Discussion for Inspectors | 1 | 6/20/07 10:53 PM |
| Romex connected to male plug... OK? | ghawley | Electrical Inspections | 20 | 3/4/07 6:05 PM |
| dryer 240 burnt plug | Rafael | Electrical Inspections | 17 | 4/12/06 2:22 PM |
| Romex wire connected to standard male plug. | ghawley | Electrical Inspections | 2 | 3/2/06 1:35 PM |
