Q: A gas appliance fuel connector should NOT have an overall length exceeding _____ feet.
A: Answer is here |
| Find an InterNACHI certified Michigan Home Inspector (and anywhere else in North America) |
36" (3 feet) except for range and/or dryer connectors. . .
Easy answer if you know the rule about not interconnecting.
(But can you connect directly to CSST?) |
Not in my town. . .
How about with a shutoff connected to both in between the two ?
My jurisdiction requires a rigid pipe connection to a shutoff - even if the rigid pipe is only 3" long.
| Gas Again | vsantos | Miscellaneous Discussion for Inspectors | 2 | 4/15/08 8:30 PM |
| No "H" clips? | jbreazeale | Structural Inspections | 7 | 5/17/07 2:28 PM |
| Another reason to recommend CO testers | rnewman1 | Interior Inspections | 2 | 10/12/06 7:47 AM |
