Old 2/16/06, 8:17 AM
Richard Seay Richard Seay is offline
Please Note: Richard Seay is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Gas flex line in crawl space
Inspected a house today that had a flex gas line connected between two metal pipes in crawl space area. Stop valve was also present in crawl space. This was in the gas line supplying the range. Didn't seem right to me. How would you right that up?
Old 2/16/06, 9:31 AM
pkelley's Avatar
pkelley pkelley is offline
Default Re: Gas flex line in crawl space
Gas flex lines cannot pass through walls and or flooring. The Shut off valve needs to be with in reach of the appliance it is servicing.Recommending a qualified contractor repair
Was there a drip leg present?
Old 2/16/06, 6:32 PM
Thanks, you asked - Was there a drip leg present? No, I very seldom see them here. The flex line is connecting two gas pipes in the crawlspace area. It does not pass through a wall or floor. Didnt look right to me.
Richard
Old 2/16/06, 7:19 PM
Jeffrey R. Pope's Avatar
Flex gas line? That doesn't really tell us enough to give a proper response.
CSST is allowed in any location that other gas piping is allowed. If the flex gas line you were referring to was in fact, CSST, there may be no problem with that application. Also, CSST can pass through walls floors etc.
If the flex gas line was actually an appliance connector, it was probably improper. Appliance connectors are for connecting appliances, not piping.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 2/16/06, 10:56 PM
My mistake, the flex gas line was actually an appliance connector. Thanks
Old 2/16/06, 10:57 PM
JohnH515's Avatar
JohnH515 JohnH515 is offline
Please Note: JohnH515 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Jeff, is there a visable difference between CSST and appliance connector line?
John
Old 2/16/06, 11:54 PM
Appliance connectors are typically smaller in diameter and three feet long. CSST can be quite long and sized as you would expect for building supply.
http://www.gastite.com/flash.php
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 2/19/06, 10:41 AM
Here are some pictures of a fairly common set up. The CSST is run through the wall to rigid pipe, and then to an appliance connector.
The rigid piping wasn't really necessary in this case, but there's nothing wrong with the set up.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 2/20/06, 2:33 PM
Patrick Bolliger's Avatar
Unhappy Re: Gas flex line in crawl space
Here is a picture of how NOT to install the flex gas connector.
This was in a basement, passing up through a wall up to a kitchen range.
The valve has to be in the same room preferably next to the appliance. Here is the rub .. Most shut off valves for kitchen stoves are behind the appliance... Hmmm
Old 2/20/06, 6:01 PM
Also, appliance connectors are absolutely not allowed to pass through walls, floors, etc.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 2/21/06, 9:27 AM
jcundiff's Avatar
jcundiff jcundiff is offline
Please Note: jcundiff is a non-member guest and is in no way affiliated with InterNACHI or its members.
AGA website has alot of info on csst as well as appliance connectors which are a listed assembly. Also check the Fule Gas Code or IRC fule gas section.
Old 8/10/08, 12:27 PM
Harold E. Miller's Avatar
Harold E. Miller Harold E. Miller is offline
However you can access gas range valve by removing the bottom drawer (in most cases)
Old 8/10/08, 1:26 PM
Joe Funderburk, CMI's Avatar
Nor through the cabinet of the appliance. About 1/2 of every furnace I see has the appliance connector going into the cabinet itself.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 8/11/08, 11:32 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
Jeff what happened to the pictures in #8?
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 8/12/08, 12:07 AM
I have no idea. Maybe they expired after two and a half years. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Return air from crawl space WHI Inspecting HVAC Systems 11 1/9/12 7:43 PM
Crawl space in under house dnasser Structural Inspections 15 2/27/07 7:12 PM
Main sewer line vented in the crawl space jfunderburk Plumbing Inspections 3 1/15/07 6:15 PM
Strange Duct in Crawl Space jfunderburk Structural Inspections 3 1/11/06 12:02 AM
