Go Back   InterNACHI Message Board > Specific Inspection Topics > Plumbing
Plumbing Contains discussions about plumbing.
Old 9/5/09, 11:08 AM
Vince Santos's Avatar
Vince Santos Vince Santos is offline
Default gas line in concrete
Can flex gas lines be installed in concrete this way? I don't see how concrete would damage the line but is a protective sleeve needed for this application?
Vince Santos
Owner / Certified Home Inspector
StepByStep Home Services LC
(734) 748-9584
http://www.stepbystepinspections.com
Providing Home Inspection Services to Southeast Michigan
Active Rain blog
http://activerain.com/sbsinspections
ITA Trained and Certified
Reg104669Cc
Find an InterNACHI certified Idaho Home Inspector (and anywhere else in North America)
Old 9/5/09, 11:15 AM
Michael Larson's Avatar
Default Re: gas line in concrete
18. Buried or Embedded: CSST shall not be buried directly in the ground or directly
embedded in concrete
(i.e.: patio slabs, foundations and walkways)
When it is necessary to bury or embed CSST, the tubing shall be routed inside a non-metallic,
watertight conduit that has an inside diameter at least 1/2 inch greater than the O.D.
of the CSST Tubing For ends of conduit installed outdoors, the conduit shall be
sealed at any exposed end to prevent water form entering. No mechanical joint
fittings are permitted within the conduit. Note: CSST must be buried in accordance with all
local building codes.
CSST Installation Guide
"Never underestimate the difficulty of changing false beliefs by facts."
Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
or
Minnesota Home Inspector
Old 9/5/09, 11:37 AM
Thank you!
Vince Santos
(734) 748-9584
Active Rain blog
Reg104669Cc
Old 9/5/09, 1:29 PM
Jeffrey R. Pope's Avatar
Furthermore, in most jurisdictions, gas lines are not allowed to travel beneath the slab of the residence (sidewalks, patios, etc, are ok, but not under the garage or living spaces) unless installed in a gas-tight conduit, sealed at each end.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/6/09, 11:31 AM
This inspection was on a second story condominium unit so I don't know what was below the floor level. But I could not see any conduit extending out of the floor.
Vince Santos
(734) 748-9584
Active Rain blog
Reg104669Cc
Options in selecting materials for basement construction wdevries Canadian Inspectors 2 8/4/08 2:30 PM
Post tension slab labeling rchorey Structural 34 7/7/08 12:43 AM
Moisture in slabs mcyr Structural 7 8/20/07 8:33 PM
bbbb mcyr Structural 1 8/19/07 11:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 8:53 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
