Old 3/2/11, 6:14 PM
Jeff L. Gollaher's Avatar
Jeff L. Gollaher Jeff L. Gollaher is offline
Send a message via Yahoo to jgollaher
Default Gas line connected to TPR valve?
This I have not seen before.
The gas line from the wall to the TPR valve then to the gas burner at the bottom of the water heater.
There is no drain pipe routing any water from the TPR valve in case of emergency.
Going to go thru the code book for ****s and giggles.
Just wondering if anyone else has come across this strange setup.
Serving the Greater Sacramento Area
Need a home inspection in Kentucky? Check out InterNACHI's listing of Kentucky certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/2/11, 6:27 PM
Michael R. Boyett's Avatar
Default Re: Gas line connected to TPR valve?
That's a Watts 210-5 gas shutoff valve or similar.
Old 3/2/11, 6:48 PM
James H. Bushart's Avatar
I would write it up. Nice gadget, but no way to test it. It could be defective and no one will know until the water heater goes into orbit.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 3/2/11, 7:01 PM
Bob Elliott's Avatar
So do you test the TPR?
Old 3/2/11, 7:05 PM
thanks for the link michael.
The application makes sense just haven't seen it before.
Used to the old fashioned setup with a discharge pipe routed away from water heater.
thanks for the input
Old 3/2/11, 7:09 PM
Barry Adair's Avatar
so nobody gets the wrong idea, i think the one Jeff pictured is an incomplete/improper install
watts "A pressure relief valve must be installed as shown to prevent excess pressure by thermal expansion. There must be no valve between the relief valve and heater. Relief valve must be piped to a suitable drain."
the instructions are on the link Mike provided
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 3/2/11, 7:16 PM
If you are right I hope I never see one and I hope the have a real TPR along side of it.
Old 3/2/11, 7:18 PM
http://media.wattswater.com/1910217.pdf
Larry Kage, CMI
231 929 3525
Old 3/2/11, 7:34 PM
Nope...but the homeowner can...and I can see it drip and I can see where it has discharged...
James H. Bushart
314-803-2167
Old 3/2/11, 10:02 PM
clambert2 clambert2 is offline
Please Note: clambert2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
The pressure relief valve is usually installed on the water line at the front hose bib. I see them all the time with interior water heaters. I actually prefer the Watts-210 over the traditional TRP valve set up. It actually shuts down the water heater not just letting it blow off steam!
Chuck
Condensate drain line scroenne Inspecting HVAC Systems 1 5/5/10 7:07 PM
Main Line vs. Supply Line Reporting Details sshockley Plumbing Inspections 2 6/14/09 3:07 PM
Check valve first time for everything????? cbottger Plumbing Inspections 5 4/8/07 1:43 AM
