Old 2/22/10, 1:26 AM
jjones2's Avatar
jjones2 jjones2 is offline
Send a message via MSN to jjones2
Default Gas line touching flue
Is there a minimum distance a gas line can be from a gas fired water heater flue pipe. todays inspection had the flue touching the gas line. Would you recommend further review by a qualified licensed plumber on this one? Thanks in advance.
John
All Tech Home Inspections
www.alltechinspect.com
Old 2/22/10, 12:04 PM
Jeffrey R. Jonas's Avatar
Default Re: Gas line touching flue
I would recommend repairing the clearance issue, and it also looks as if the vent dips going under the gas pipe, and the vent joint connection appears to not be a tight fit.
Coming soon. Free, online, fireplace and chimney inspection course. gromicko General Inspection Discussion 15 12/14/09 4:19 PM
Gas line and boiler flue dgagneur Plumbing Inspections 0 9/13/09 11:27 PM
What's Inside A Chimney mcyr Inspecting HVAC Systems 14 9/17/08 6:11 PM
TPR drain line touching floor mpettitt Inspecting HVAC Systems 7 2/26/06 3:13 PM
